Poulan 3416
pistonslap Posted By pistonslap, Sep 24, 2007 at 12:23 PM
Thread Status:
  1. pistonslap
    pistonslap
    Burning Hunk 2.
    NULL
    Oct 7, 2006
    219
    0
    Loc:
    southwestern Pa.
    After finally getting my carb adjusted and the saw working decently again. I think I may have found my original cause of stalling and plug fouling. When I started cutting again, after the saw got good and warmed up it started to bog down. I pulled it out of the piece to rev it, but it seemed like the chain brake was engaged. The lever was in the disengaged position but the chain wouldn't turn. After the saw stalled out, the chain was free again. Is anybody familiar with how the chainbrake works? Is it a job that can be repaired by someone who is reasonably mechanically inclined? There was a link in one of the threads to a web page that showed parts lists and blow-up diagrams for poulan saws but I can't find it. If anyone has this link, could you post it again? I know it's not a top of the line saw, but it has performed pretty much flawlessly up until now. I'd like to take one more stab at fixing it.
  2. pistonslap
    pistonslap
    Burning Hunk 2.
    NULL
    Oct 7, 2006
    219
    0
    Loc:
    southwestern Pa.
    I decided to do surgery anyway. The chainbrake operates on the same principal as an oil filter wrench. A steel band goes around the clutch cover. when you push the lever forward it tightens the band and stops the chain. It was really gunked up with oily sawdust. I won't know if that was the problem until I get a chance to cut. One thing for sure, cleaning the chain brake will become a part of my routine maintenance.
  3. fire_N_ice
    fire_N_ice
    Member 2.
    NULL
    Aug 27, 2007
    148
    0
    Loc:
    Monmouth County, NJ
  4. fire_N_ice
    fire_N_ice
    Member 2.
    NULL
    Aug 27, 2007
    148
    0
    Loc:
    Monmouth County, NJ
  5. pistonslap
    pistonslap
    Burning Hunk 2.
    NULL
    Oct 7, 2006
    219
    0
    Loc:
    southwestern Pa.
    Thanks. that's the one I was looking for. I got it to start and run and cut well, but trying to get it to restart it after you shut it off while it is still warm is almost impossible. There may be a Husky in my future.
  6. pistonslap
    pistonslap
    Burning Hunk 2.
    NULL
    Oct 7, 2006
    219
    0
    Loc:
    southwestern Pa.
    I bought a Husky 142 today. It was $200 at sears. I bought the 16". It was $30 more for the 18", but it had the same size motor as the 16" That's $200 for the saw and $300 for the splitter. The gas company was granted an 11% rate hike this week which is supposed to cost the average homeowner about $35 more a month. So that means I will make that money back that much faster. I think the poulan will work fine as a back up saw to give the Husky a break so that I don't overheat it.
  7. Hogwildz
    Hogwildz
    Minister of Fire 2.
    NULL
    Nov 3, 2006
    8,020
    1,648
    Loc:
    Next to nuke plant Berwick, PA.
    My Poulan Wildthing does the same thing, the oily sawdust builds up around the chain brake. Had to clean it out, then ran fine.
    Does tend to run like crap when its warm out and have been cutting for a bit. Won't hold an idle.
  8. Tony H
    Tony H
    New Member 2.
    NULL
    Oct 24, 2007
    1,156
    1
    Loc:
    N Illinois
    My poulan 3145 does the same thing when it gets warm and my buddy that has the same saw has the same issue ... seems to be an issue with these saws, I am considering a husky. BTW the thing always dies when I set it down to move cutting a large tree and throwing it does not seem to help at all !
  9. Lignums
    Lignums
    New Member 2.
    NULL
    Oct 14, 2007
    181
    0
    Loc:
    Cincinnati
    Since we are bashing Poulan's a little bit, my buddy at work has a Poulan 4620 avhd and has trouble getting oil to the chain. I have watched him cut a number of times and the usual oil to gas ratio usage on a normal saw is one tank of gas for almost a tank of bar oil, but his is almost nil. When it was new it used a tank for tank but that was only for the first few times he used it. Have any of you guys out there experienced this? On the Internet I have read some reviews that said the same thing, but on various models of Poulan's. It would seem that even a little bit of saw dust can clog the oiler up. And if you have had that problem and fixed it, can you explain how? He has been bothered with this for some time now and doesn't really want to spend $100.00 of a $200.00 saw to get it repaired. Thanks for any advice or tips.
  10. Tony H
    Tony H
    New Member 2.
    NULL
    Oct 24, 2007
    1,156
    1
    Loc:
    N Illinois
    Now that you mention it my Poolan also uses less oil than when it was new so it may have the same problem. I am going to take it apart and get it all cleaned up to use as a backup and for small jobs because I broke down and got a Stihl MS250 18" for primary use. The guy I got the saw from owns a tool rental place and suggested to remove the bar and blow it out after each use (any brand) and it will help keep it running longer.
  11. Bones
    Bones
    Member 2.
    NULL
    Feb 16, 2007
    154
    28
    Loc:
    Tennessee
    I just got the POOOOlan 4620 yesterday and ran great for about 20 - 15" rounds today. Now no oil to the bar. Took it all apart and cleaned everything, still no oil.
    Called Poulan and was told to take it back. Not a very happy camper at this point with less than a tank of gas !!!!!
  12. struggle
    struggle
    Minister of Fire 2.
    NULL
    Oct 24, 2006
    727
    0
    Loc:
    NW Iowa
    I am glad I was not drinking anything when I read that. That was funny :lol:
  13. pistonslap
    pistonslap
    Burning Hunk 2.
    NULL
    Oct 7, 2006
    219
    0
    Loc:
    southwestern Pa.
    As I have said before, I got really good results for a hundred dollar saw. But mine stalled a lot too and being a poulan the pullrope would stop retracting after about 4-5 pulls. My buddy used to call it the flying Poulan.
  14. Bones
    Bones
    Member 2.
    NULL
    Feb 16, 2007
    154
    28
    Loc:
    Tennessee
    Took the POOOlan back and talked myself into a HUSKY 350 instead of trying another Poulan.
Thread Status:
