Quadra-fire only runs for 10 min
Post in 'The Pellet Mill - Pellet and Multifuel Stoves' started by tacoma245, Feb 6, 2007.
Thread Status:
  1. tacoma245
    tacoma245
    Expand Collapse
    Feb 6, 2007
    19
    0
    Hello there,
    I have a quadrafire mont vernon pellet stove that will only run for 10 minutes or so before shutting down. The call light stays on the whole time and the room never reaches the proper temperature. After it does this, I can turn the thermostat down and back up again and the stove will fire up and run for another 10 min. Sounds like maybe a snap disk? How do I go about resloving the issue?
    Helpful Sponsor Ads!
  2. MountainStoveGuy
    MountainStoveGuy
    Expand Collapse
    Jan 23, 2006
    3,654
    2
    Loc:
    Boulder County
    is the thermo couple cover complety seated on the thermocouple?
    will it light?
    Collapse Signature Expand Signature
  3. tacoma245
    tacoma245
    Expand Collapse
    Feb 6, 2007
    19
    0
    Yes, I even tried replacing it. It fires up fine and seems to run good until it shuts down. I was told it was probably the thermostat but that seems weird because the call light stays on.
  4. MountainStoveGuy
    MountainStoveGuy
    Expand Collapse
    Jan 23, 2006
    3,654
    2
    Loc:
    Boulder County
    Yea if the call light is on then it should be calling for heat/
    are you getting past the startup phase?
    the stove calls for heat
    it drops pellets and the ignitor stays on for 1.5 minutes
    the pellets light
    the thermocouple senses heat and starts the auger back up
    the thermocouple senses heat and starts the covection fan up
    how far along are you getting in that sequence?
  5. tacoma245
    tacoma245
    Expand Collapse
    Feb 6, 2007
    19
    0
    It shuts down after the convection fan runs for a few minutes. After it shuts down the fan continues to run for another 5 minutes or so.
  6. MountainStoveGuy
    MountainStoveGuy
    Expand Collapse
    Jan 23, 2006
    3,654
    2
    Loc:
    Boulder County
    aslo, have you changed fuel types?
    what are you burning?
    Does the auger stop turning or do the pellets just burn up to fast for the machine to keep up?
    Did you make sure that the thermocouple COVER is clean on the inside? ash in there will give it false readings
  7. MountainStoveGuy
    MountainStoveGuy
    Expand Collapse
    Jan 23, 2006
    3,654
    2
    Loc:
    Boulder County
    well if the convection fan comes on the the auger is feeding pellets, so the auger snap disk cant be bad.
    it sounds like a control board issue to me. Unplug the stove, take out the control board and plug it back in.
    have you switched fuels latley?
    aslo start the stove in the "quad" position
  8. tacoma245
    tacoma245
    Expand Collapse
    Feb 6, 2007
    19
    0
    I have tried cleaning the thermocouple cover and will check that agian. I have tried 3 or 4 different types of pellets to no avail. The does stop turning before it shuts down as though it is going through a proper shut down.
  9. tacoma245
    tacoma245
    Expand Collapse
    Feb 6, 2007
    19
    0
    the auger does stop turning
  10. MountainStoveGuy
    MountainStoveGuy
    Expand Collapse
    Jan 23, 2006
    3,654
    2
    Loc:
    Boulder County
    the fact that the auger comes back on after the start up process kind of rules out the snap disk.
    If you have cleanded the cover its clean. is it sticking far enough in the pot?
    open your hopper restrictor all the way and turn the stove to quad and see if it shuts down, if it does, its likeley a control board issue if its not a thermocouple issue. Your tubes on your vacume switch are on tight right?
  11. MountainStoveGuy
    MountainStoveGuy
    Expand Collapse
    Jan 23, 2006
    3,654
    2
    Loc:
    Boulder County
    since the auger stops turning, one of three things is happening. the stove looses pressure, the thermocouple drops down in temperture, or the control board is not sensing temperture.
    if the aguer never comes back on after start up that would point to a snap disk, but since the convection fan comes on it would have to drop more pellets to get the couple hot enough for that to happen.
  12. tacoma245
    tacoma245
    Expand Collapse
    Feb 6, 2007
    19
    0
    The stove ran fine for the first year I had it, but started acting up last year. The thermocouple is sticking over the pot to the specs in the manual. ~2" I will try your reccommendation and check the tubes as well. I didn't know if it was some sort of issue with the exhaust getting too hot?
  13. MountainStoveGuy
    MountainStoveGuy
    Expand Collapse
    Jan 23, 2006
    3,654
    2
    Loc:
    Boulder County
    i was assuming that you cleaned the flue. Have you?
  14. tacoma245
    tacoma245
    Expand Collapse
    Feb 6, 2007
    19
    0
    My appologies if I screwed up the terminology. Is the fan that blows the air through the exchanger tubes the convection fan? That is the fan that still runs after it shuts down.
  15. MountainStoveGuy
    MountainStoveGuy
    Expand Collapse
    Jan 23, 2006
    3,654
    2
    Loc:
    Boulder County
    and it should, the combustion fan should run too, otherwise your house would fill up with smoke.
    If there is a lot of ash in the pipe that will trip the vacume swich too. Make sure your chimney is clean before you go any further. Do you live in altitude? is it vented strait back?
  16. tacoma245
    tacoma245
    Expand Collapse
    Feb 6, 2007
    19
    0
    I replaced all of the piping when I moved upstairs from the basement. It seemed to be clean from what i could see looking into the stove with no piping on it. It did sit in a moist basement for a summer too so I don't know if there is something in particular I should check for rust?
  17. MountainStoveGuy
    MountainStoveGuy
    Expand Collapse
    Jan 23, 2006
    3,654
    2
    Loc:
    Boulder County
    nahhhh... this is electrical.
    So the stove hasnt worked properly since you have moved it?
  18. tacoma245
    tacoma245
    Expand Collapse
    Feb 6, 2007
    19
    0
    the piping runs out of the stove to a 45 degree and then straight out.
  19. MountainStoveGuy
    MountainStoveGuy
    Expand Collapse
    Jan 23, 2006
    3,654
    2
    Loc:
    Boulder County
    im thinking its the control board, what did your dealer say?
  20. tacoma245
    tacoma245
    Expand Collapse
    Feb 6, 2007
    19
    0
    It started doing this just before I moved it upstairs.
  21. tacoma245
    tacoma245
    Expand Collapse
    Feb 6, 2007
    19
    0
    The dealer was the one who said it was probably the thermostat. ??
  22. MountainStoveGuy
    MountainStoveGuy
    Expand Collapse
    Jan 23, 2006
    3,654
    2
    Loc:
    Boulder County
    the thermostat simply opens and closes a circuit. Thats simple to trouble shoot. disconnect the wires from the stat and twist them together.
  23. MountainStoveGuy
    MountainStoveGuy
    Expand Collapse
    Jan 23, 2006
    3,654
    2
    Loc:
    Boulder County
    please make sure that the control board is properly seated in its wiring harness. They come loose easily.
  24. tacoma245
    tacoma245
    Expand Collapse
    Feb 6, 2007
    19
    0
    Thats what I thought. Especially seeing that the call light stays on.
  25. tacoma245
    tacoma245
    Expand Collapse
    Feb 6, 2007
    19
    0
    I will check that tonight. Thanks for your help.
Thread Status:
