QuadraFire Mt. Vernon won't feed
GeeBee93
2
Perth, Ontario, Canada
Hello everyone, this is my first post on here, I hope someone can help. I have a 2006 Mt. Vernon that quit feeding pellets. Thanks to this site I have done the following troubleshooting: Snap disk #2 is working - completed circuit tested with multi meter. Snap disk #3, same thing. Vacuum switch bypassed. Snap disks also bypassed just to be sure. No power from the control box (red wire). Auger motor working, checked by supplying power directly to it. Call light comes on, push reset and fan speed changes momentarily, and you can hear a click. No pellets. Took cover off clear control box and looked for a burnt mark on circuit board, couldn't see one. Any suggestions? Anything I missed? Thanks for any help!
If you have verified all the rest of the parts, which it looks like you have, then the only option left is a circuit board. They do not always scorch or burn when they go out and that would be my biggest suspect given what you have described.
Best way to find out is find someone with same stove and have them try it in theres. kap
Sounds like what you need, but you can always test it in someone else's stove. kap
