    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. rockreid Member
    Stamford, CT
    I have a Jotul Rockland that I am planning on taking with me to my new house. Is it OK for a normal wood burning fireplace to still have the stainless liner left inside the chimney? Or should I remove the liner for the new owner of my present house?
    I will have to reinstall the little flue flap? Is this a big job to do?
    #1
    Helpful Sponsor Ads!
  2. Jags Super Moderator
    Northern Illinois
    I would make SURE that if you left it, that the Realtor or next owner knows of it. It could cause issues if they went back to a basic fireplace. The flue flap? That of course depends on how you removed it. If you disassembled it, it should reassemble just fine. If you cut it out - it could be a real job.
  3. pen Super Moderator
    N.E. Penna
    As jags said, if that liner is left in place make sure everyone knows that it cannot be used as an open fireplace! Perhaps even use some insulation and block the opening entirely and leave a note taped in there somewhere.
  4. begreen Super Moderator
    South Puget Sound, WA
    Removal of the damper is an alteration. If there has been alteration to the original fireplace it must be clearly stated. Ideally there should be a sign permanently and prominently attached to the back of the fireplace stating the fireplace has been altered and can only be used with a proper insert.
    Check with the realtor first. If this could be a deal breaker and you are trying to move the house quickly, it may be better to leave the insert in as a selling point.
  5. jeff_t Minister of Fire
    SE MI
    It should be noted in the seller's disclosure. Also, any inspector better find it.
    If the damper can be reinstalled without a lot of work, I would pull the liner and do it. A fireplace can be a big selling point to a lot of buyers, but a dedicated wood burning appliance only has value for the right buyer. Will the liner be usable at your new place?
