    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. NH_Wood Minister of Fire
    southern NH
    Hi everyone,
    What is the best option for fixing a crack on a chainsaw handle - I'm looking at a possible MS260Pro, but has a crack in the handle - from what I understand, the handle is cracked near where the trigger portion meets the base - not sure if it's a full separation or not.
    Is there an epoxy that can be used to seal the crack? Does it require a new housing/handle? Sorry for no strong details, just wondering if this is a deal breaker - the rest of the saw seems in very good shape.
    Cheers!
    #1
    Helpful Sponsor Ads!
  2. 711mhw Feeling the Heat
    Western ME
    I can't speak to that exact saw, but I "ran" with a cracked handle on my old fav. 044 for a long time. I finally parted with about $260 for the new part (only) that is basically the "chassis" for the whole saw. Now were both happy!
  3. Backwoods Savage Minister of Fire
    Michigan
    JB Weld.
    Wildo and MasterMech like this.
  4. NH_Wood Minister of Fire
    southern NH
    Thanks guys - I'll look into the JB Weld - geesh, $260 seems real steep for the housing - that must have been painful! Cheers!
  5. MasterMech Minister of Fire
    Hudson Valley NY
    Check eBay for replacement handles too. JB Weld is sold at just about every hardware and parts store.
  6. NH_Wood Minister of Fire
    southern NH
    Checked on eBay - seems like a lot of after market stuff and pretty damn expensive.......I'll have to see how bad the crack is when I see the saw. Thanks!
  7. MasterMech Minister of Fire
    Hudson Valley NY
  8. NH_Wood Minister of Fire
    southern NH
    Thanks MM. Man, it seems that 40-60 bucks for a rear handle seems real pricey, but, I haven't done a lot of part searching. Cheers!
  9. MasterMech Minister of Fire
    Hudson Valley NY
    Go ahead, call your dealer and ask. You know you want to. ;)
  10. NH_Wood Minister of Fire
    southern NH
    Ha!
  11. cygnus Feeling the Heat
    Central, NJ
    I'd stay away from the aftermarket assembly. I put one on an 038 and found that the old filter cover wouldn't fit. Turned out I needed to buy the matching aftermarket cover too. I had to trim some of the plastic to get it on and the metal 'clasp' works like crap. It wasn't worth the few bucks I saved.
    Check eBay or chainsawr.com. If you have the energy, you could get something like a complete non-working saw, pull the parts you need and sell off the rest.
  12. Dune Minister of Fire
    It is likely an aluminum/magnesium alloy which can be welded as long as the alloy can be identified.
    I wouldn't buy it, though since you may not be able to find a welder who can fix it.
  13. rkshed Member
    Bedford NH
    Until I found a donor saw for my Jred 455, I reinforced the cracked handle by bolting a mending plate over the crack.
  14. NH_Wood Minister of Fire
    southern NH
    Thanks for all the info! Cheers!
  15. MasterMech Minister of Fire
    Hudson Valley NY
    Every 026/MS260 I've come across has a plastic back-handle. But Dune is right that Mg/Al can be TIG welded quite readily in the right hands. ;)
    Dune likes this.
  16. NH_Wood Minister of Fire
    southern NH
    I have a right hand, but not the right hands! Cheers!
    MasterMech likes this.
  17. Danno77 Minister of Fire
    Hamilton, IL
    If its a 260 then it's the plastic or composite or whatever they call it. There were some 026s that had the metal, iirc.
