Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
I want to run my single wall stove pipe up the wall and out the roof, I will have a stone wall behind it, can you tell me what the clearance between the stove pipe and the stone wall has to be? Thanks.........
If it's a framed wall structure (combustible) behind the stone, and the stone is built right against the wood framing, then the stone wall gives you about a 33% allowable reduction in clearance, so the single-wall stovepipe could run 12" (instead of 18") from the combustibles, or about 8" away from the stone. How close are you wanting it to be? If you build that wall so it's stone throughout to daylight, with no combustibles involved at all, then you have no minimum clearance requirement. It'll have to stand off from the wall at least a few inches, because the ceiling box you're going to need where you transition from stovepipe to Class A chimney pipe takes up about a 10" x 10" footprint, whether it's square or round. Rick
The fundamental question is, is the wall combustable or not? If the stone is structural, or the walls are cinderblock etc.... Then you can let that thing get as close as you'd like to the wall.......
