Radon fan
PennPellet Posted By PennPellet, May 11, 2014 at 8:25 AM
Thread Status:
  1. PennPellet
    PennPellet
    Member 2.
    NULL
    Jan 13, 2014
    45
    4
    Loc:
    Pennsylvania
    Any specific clearance a vent pipe should have to an external radon fan?
    Thanks again!
  2. peirhead
    peirhead
    Feeling the Heat 2.
    NULL
    Aug 8, 2008
    407
    30
    Loc:
    PEI Canada
    I would keep it away from an OAK inlet if you are using one....Perhaps if you are worried about Radon it would be better to use household air for combustion anyways to help remove it. As far as clearance to just the stove exhaust I doubt it matters....This is all assuming the Radon fan is set up to remove household air, not to bring in fresh air!!
  3. sinnian
    sinnian
    Minister of Fire 2.
    NULL
    May 28, 2008
    894
    54
    Loc:
    Limerick, Maine
    Radon fan is pushing out, not pulling in.
  4. peakbagger
    peakbagger
    Minister of Fire 2.
    NULL
    Jul 11, 2008
    2,804
    618
    Loc:
    Northern NH
    Radon is heavier than air so it will tend to migrate downwards so a fresh air vent to a stove would best be mounted above it. Arguably any radon that gets reintroduced goes into the combustion chamber and out the exhaust so it doesn't get back into the living space.
    I
    DneprDave likes this.
  5. smwilliamson
    smwilliamson
    Minister of Fire 2.
    NULL
    Dec 28, 2009
    4,501
    782
    Loc:
    Southcoast, MA
    Radon fan is only pushing when it's 'on'
  6. chken
    chken
    Minister of Fire 2.
    NULL
    Dec 7, 2013
    1,102
    226
    Loc:
    Maine
    Well, I doubt it should matter since the radon gas, >5ppm, will go in your OAK, and then out your exhaust vent. BTW, most radon vents, vent above the roofline, like your stove exhaust, nowhere near an intake.
  7. daffonce
    daffonce
    Member 2.
    NULL
    Jan 23, 2013
    109
    21
    The radon usually vent above your roof line no worries about sucking it in. I think your only concern would be its proximity to the exhaust because of heat. Id recommend you go with your vent manufacturer or stove manufacturers spec. I think 3" is somewhat usual.
  8. batchman
    batchman
    Burning Hunk 2.
    NULL
    Oct 29, 2013
    166
    33
    Loc:
    Backwoods MA
    Radon is an interesting point to consider. If you have a radon mitigation system, which draws air from under the foundation and vents to outside, I would highly suggest an outside air kit. Don't really want to compete with the Radon system by drawing that air into the house.
    While my Radon system is no where near my stove, it has the fan outside in a pvc box with pvc pipe. That's the aspect that would drive the spacing in my case, which I would take as the same as to vinyl siding.
    Good luck,
    - Jeff
Thread Status:
