    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. toysrwill New Member
    Hello,
    I am looking at installing a propane direct vent fireplace on an interior wall. If I go with a rear vent fireplace, upon exiting the fireplace can i use a 90 degree elbow and turn immediately to the right and run a horizontal pipe out? I'm assuming I need to use some rise, its about 7 feet maximum to get out of the room and out the house to the termination area.
    Also is there any benefits over rear vent vs top vent on propane fireplaces?
    Thanks
    Will
    #1
    Helpful Sponsor Ads!
  2. FanMan Member
    CT stix
    Whether you can use a long horizontal run will depend on the specific fireplace; the manufacturer's installation instructions will give information on the venting requirements. I know on mine (which is a top vent) there is a minimum vertical rise before any elbows. OTOH, some fireplaces are made to be installed on interior walls with a long horizontal run, but they may require power (fan assisted) venting, which means it won't run without electricity if that's important to you.
