    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. pybyr Minister of Fire
    Adamant, VT 05640
    Hello all-
    Would really like to have a simple way to kick on my oil furnace from away from home, only occasionally, and only as needed, for situations when I am not able to tend the wood fire on a sufficiently timely basis, just so that the oil furnace can start to take the chill off before arriving home.
    I truly don't want some uber sophisticated or uber spendy cutting edge whizbang solution/ home automation extravaganza.
    In fact, as someone with too many projects competing for time and budget, I really don't want this to turn into a significant undertaking of time or $ or one more thing to learn the ropes of.
    I am very at ease with electronics but I want something as complex to operate as a brick.
    Some simple cheap way to toggle a relay by web access or phone DTMF would do the job splendidly.
    Appreciate any suggestions
    Thanks!
    #1
    Helpful Sponsor Ads!
  2. WhitePine Feeling the Heat
    Google DTMF remote relay. You will get a lot of results, including how to instructions. The same terms on eBay will also bring up some products. I don't know if any of them will meet your exact requirements, but something workable should be out there.
  3. woodgeek Minister of Fire
    SE PA
    Personally, I think you should shell out a little more and buy a (cheap) wifi tstat. I think there are some under $100.
    That way you can also monitor your temps remotely, some might email you if things get too cold, etc.
    WhitePine likes this.
