Run a Hydrostatic Lawn Tractor on Part Throttle When Not Mowing?
velvetfoot Posted By velvetfoot, Jun 5, 2013 at 10:12 AM
Thread Status:
  1. velvetfoot
    velvetfoot
    Minister of Fire 2.
    NULL
    Dec 5, 2005
    9,430
    711
    Loc:
    Sand Lake, NY
    I've been doing that at half throttle, but yesterday I tried running around at lower than that. I noticed it bogged down a little going up a hill, and I bumped up the throttle a little, and up it went.
    Am I doing any harm, as long as it's pulling smoothly?
  2. smokinj
    smokinj
    Minister of Fire 2.
    NULL
    Aug 11, 2008
    15,981
    1,412
    Loc:
    Anderson, Indiana
    Yea that pretty much what I do. I do not run full throttle unless pulling something or mowing. I put it down to idle for 20 seconds or so before turning off.
  3. jeff_t
    jeff_t
    Minister of Fire 2.
    NULL
    Sep 14, 2008
    4,163
    1,114
    Loc:
    SE MI
    Me, too, but I let it idle for a couple of minutes before I shut it off. Let the fans cool the engine and hydros off a bit.
    My mother in law lives on a river, and has a steep hill in her back yard. She called one day and said her JD wouldn't go up the hill anymore, even when not mowing. I looked at it, started it up, and finished mowing for her, downhill and up. She was flooring the pedal going up the hill, like a gas pedal. I had to explain to her how a hydro works, and she needs to let up on the pedal going up the hill for more power, like downshifting. I'm still not sure she understands, but she does it.
    MasterMech and smokinj like this.
  4. velvetfoot
    velvetfoot
    Minister of Fire 2.
    NULL
    Dec 5, 2005
    9,430
    711
    Loc:
    Sand Lake, NY
    Thanks. I've gotten used to the hand controls on my Ariens, and I think foot controls might be a hindrance when leaning over on the hill. :)
  5. smokinj
    smokinj
    Minister of Fire 2.
    NULL
    Aug 11, 2008
    15,981
    1,412
    Loc:
    Anderson, Indiana
    Foot peddles make for really fast turns. Mine has one pedal for forward and reverse and coupled with a stirring wheel knob awesome. I have a ditch that's pretty pitchy no issues.
    Ashful likes this.
  6. gzecc
    gzecc
    Minister of Fire 2.
    NULL
    Sep 24, 2008
    4,458
    870
    Loc:
    NNJ
    Just realize that the hydro is supplied with more or less fluid depending on the rpms that your've selected. If your under any additional load, you should have the rpms up high to supply the hydro with as much fluid as it wants.
  7. MasterMech
    MasterMech
    Guest 2.
    NULL
    Part throttle is fine for light transport but with any real load on it..... Wind 'Er up. The extra airflow from the fan will benefit the trans longevity. Heat is the enemy.
  8. lukem
    lukem
    Minister of Fire 2.
    NULL
    Jan 12, 2010
    3,687
    1,518
    Loc:
    Indiana
    Just have to find the sweet spot in terms of engine RPM and hydros. If you hear the pump groaning give it more RPM or less forward speed. More throttle is cooler operation but wastes gas if you aren't challenging the machine.
  9. velvetfoot
    velvetfoot
    Minister of Fire 2.
    NULL
    Dec 5, 2005
    9,430
    711
    Loc:
    Sand Lake, NY
    It's hard to believe they only get 20 hp. out of 650 cc.
    This machine isn't a zero turn thing, whatever it's called.
  10. MasterMech
    MasterMech
    Guest 2.
    NULL
    That has a lot to do with the fact that the compression is relatively low compared to say.... a Suzuki SV650 (650 cc 90 deg V-Twin, 70 ish bhp) and the max RPM is 3600 give or take. Whereas the motorcycle engine is redlining over twice that. (my SV1000 was red-lined at 11K)
    HP = Torque x RPM / 5252
    Figure out what the motorcycle makes for HP at 3600 rpm and I'm guessing it'll be closer than you think. ;)
  11. lukem
    lukem
    Minister of Fire 2.
    NULL
    Jan 12, 2010
    3,687
    1,518
    Loc:
    Indiana
    Lawnmowers don't need HP as much as they need torque. My 850CC only puts out 31 HP...small 1100CC diesels only put out about 28HP, but 70ish lbft.
Thread Status:
