Ryobi wood splitter leaking fluid/can it take it
johnsopi
696
MD near DE&PA;
Used the Ryobi to splitt 4.5 cords of sweetgum worked well. Put it away for a few days took it out again. Starting leaking fuild before splitting one log. I took it back to Home depot it was under the 30 days and got a new one. Is it normal to have to add the fluid? or did the seal go. Is the Ryobi made tough enough to handle
a lot of use? It made processing the wood a lot easier. Hope this one holds up. I have another big pile to splitt.
Did you determine precisely where and why it was leaking? My first thought is about the bleed screw which can leak fluid if you tilt the unit with this screw open.
I don't think it was the bleed screw., but it could been. I thought it was around the piston,but the fluid could have run down there.
the bleed screw is right next to the piston. I sometimes forget to close my bleed screw, but I lift it from that end so I haven't leaked any yet.
I'm still ecstatic about mine. I dropped, bucked and split a hickory tree today and listened to a football game from my garage TV.
probably an O ring rubber gasket
Hydralyic fluid is cheap (sorry for misspelling)get it any auto parts store for less than $3 /quart.
