Safe temps for 0" clearance?
Post in 'It's a Gas!' started by pcampbell, Jan 22, 2009.
Thread Status:
  1. pcampbell
    pcampbell
    Expand Collapse
    Jan 3, 2008
    120
    0
    Loc:
    Vermont
    I have a DV wall furnace that is listed as 0" clearance to combustibles. I measured the pipe temps today with my infrared gun and found the hottest temps to be around 240F. I am just wondering what is considered the maximum safe range for clearance to framing wood, drywall, etc.
    Helpful Sponsor Ads!
  2. R&D Guy
    R&D Guy
    Expand Collapse
    Apr 25, 2007
    375
    1
    Zero clearance is likely just for the unit, not the pipe. Pipe almost always has clearance required. The install manual should specify this. If its 240° F and touches wood/combustibles then I'm sure its too hot. If it's 240° and there is an air gap then you need to measure the surface temp of the surrounding combustibles.
    ANSI Z21.88a-2007 is the standard fireplaces are certified to today, your furnace is likely a variation of that standard, but Z21.88 says any combustible surface not exposed to the room (not seen e.g. inside the wall) has a maximum temperature limit of 90° F above ambient temperature. So if your house is 70° inside, the combustible cannot exceed 160°. That temperature measurement is taken when the system is at equilibrium (hottest).
    If you are concerned then I don't think there is any reason you can't add extra clearance. I've been guilty of that before.
    Collapse Signature Expand Signature
Thread Status:
