safety heat dump vents on wood furances
johnsopi
696
MD near DE&PA;
Do any folks use the safety heat dump vents on their wood furances? One place has them for @100
it is a 14"x14” vent that has a heat fuse that open the vent door at 350. I have a normal vent in my Plenum
that I keep open all the time 6x 10. I had not thought to much about untill we lost power Tuesday.
This link may help. Charmaster recommends a lower temp link, 280°F. They sell a heat dump for $82.
http://www.charmaster.com/pwout.html
Ideally the system would be set up for maximizing convective flow, but that isn't always possible. First rule when installing a wood furnace is to be sure the main plenum clearance to combustible is at least 18", particularly at the furnace. Then there should be at least a 6" air space for the first 6' of horizontal primary run from the furnace. A sheet of cement board over the plenum is not a bad idea either.
