    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. QandA New Member
    Question:
    I love woodburning stoves and would like one in my basement. The basement, like most, is cold and drafty. Thus, for my own enjoyment and for heating purposes I would like to put woodburning stove in the basement to help keep the basement livable. Is it at all possible to use the same chimney as the normal furnace uses( which is also in the basement and located close to where I would like to put the stove)? The chimney is brick. If I can't, is there any way I can make use of the existing chimney, or do I just need to build a brand new system?
    Answer:
    It's best for a woodstove to use its own chimney. That can cost a bundle, but it's really the only way to go. If your furnace is gas, you might be able to install a lower cost chimney for your furnace and then use your brick chimney for the stove...this might save some $$
    #1
    Helpful Sponsor Ads!
Thread Status:
