Santa fe not feeding
Rich B
4
pleasant valley, NY
I have a 2005 Quadra fire santa fe, which stop feeding pellets. I hooked up the auger motor direct and it runs fine, I jumped all snap disks. I have only 85 volts feeding the auger. I checked for 120 volts going into control and there is 125 Volts The red wire coming out of the control going into vacuum switch is 85 volts. Is this indicative of a bad controller? If I add pellets by hand everything works fine.
Thank You
Rich B
Is it not feeding at all or stops after the start up sequence? The vacuum line might need to be blown out and the nipple cleaned of a blockage at the pellet chute and check the vacuum switch to make sure it works correctly would be the next checkpoints.
i have cleaned the tube and also by passed the vacuum switch i have 85 volts going into the vac switch and 85 coming out same goes for the snap disk 2.
thanks for the quick response
Rich B
I am sorry for not being more helpful. I have been running like a chicken with my head cut off lately. I am glad it is fixed though.
