I know another weak spot on them is the ignition. It has the sem coil and they're still available through stihl. So that's a plus. The not so good about that coil is its $230. I have a 056 mag 2 on my work bench that I am putting a new sem coil on. If I would get it, I am gonna do some research and will port it. Or send it to have ported.They’re only real weak spot was the mounts and handle bars. Contrary to popular belief, timber fallers can be pretty brutal on a power head especially if it gets pinched lol. Chopping yourself out or worse, having to ask a nearby cutter to saw you out was highly frowned upon. It rarely happened but the occasional pinch is pretty common. I used to have a boneyard of parts until the 66. The outer clutch and gearing would probably make it a decent mill saw candidate but not a speed demon by any means
Yes I know timber cutters are hard on saws. My father in law is one. Especially when you have a few month old ms462 and it gets ran over by the skidder. Ouch.They’re only real weak spot was the mounts and handle bars. Contrary to popular belief, timber fallers can be pretty brutal on a power head especially if it gets pinched lol. Chopping yourself out or worse, having to ask a nearby cutter to saw you out was highly frowned upon. It rarely happened but the occasional pinch is pretty common. I used to have a boneyard of parts until the 66. The outer clutch and gearing would probably make it a decent mill saw candidate but not a speed demon by any means
I say if you can afford it you better own it. After a couple shoulder surgery's I just don't mess with the old chain saws any more. The last few times we needed my 660 on a couple trees I let my buddy run it. Can't say I ever saw a 056 around here. A fellow in my area used to run a 090 with a five foot bar on it. I had him take down a couple big cotton woods with it years ago. Not for sure were that saw went when he passed away ten years ago.I need some advise and input. I came across an stihl 056 magnum 2. The engine is complete and has about 90% of the other parts to finish. Guy said it has 160psi compression. I have always wanted one of these beasts. I think i would restore it. I can get it for $200. What do you guys think?
View attachment 293310 View attachment 293311 View attachment 293312 View attachment 293313
That's what the guy said so who knows. It's his word against mine. If I would try to flip it, I agree on you can never get your labor back out of it. Especially on a project saw. The parts he mentioned that it needed was the fuel line in the tank, some screws and a couple of av buffers. So far I can come up with the parts that it needs that he said. But I won't know until I get started with it. He said it ran before he took it apart. He took it apart due to the rotted fuel line in the tank. So it a 50/50 chance. It's definitely not a saw I will run that much. But would be cool to have an old muscle saw with a bigger bar for the times you need it.I guess if you want it, get it. The only a couple points I can offer:
- 160 psi seems almost suspiciously high to me. Possibly I'm wrong, possibly the number is BS, or possibly the saw is really just that 'hot'. But I'd just make sure it has not had work like an extreme port job or shaving the head/cylinder to make it some sort of hard to run 'race saw'...unless you want something like that.
- My experience with "90%" projects is typically "I have the easy 90% done... the other 10% parts are out of stock, unobtanium, extremely expensive, need to be custom made, or one comes up on ebay every 10 years or so." Just be sure to take careful stock of what you actually need to finish and make sure that fits in the budget, or possibly you have your own spares to put in.
- If you're fixing up with the plan to turn a profit - I don't know that I've ever rebuilt anything where I felt I got the parts value out of it much less my time/labor. Possibly I'm just working on the wrong junk, though! But if this is for fun/enjoyment, then that is ideal. If it is to turn a profit, that is another thing to consider - especially in light of the point above.
Good luck and have fun!
Ok ok ok ok, you can quit twisting my arm. 200+ saws? What monsters do you have? You almost have enough saws for everyday of the year.Just buy it...
says the guy with 200+ saws.
That's pretty awesomeeI have been concentration on acquiring monsters for the last while...
Big CC,old ,geardrive.
I have been collecting PM Canadiens there are a couple left i haven't found yet.Have most of the 0 series of Stihls.Have one of each model Hornet made
I have a semi trailer for my saw storage,plus a wall full at my shop,Plus a bunch in my Boiler building.
200 is probably conservative,it depends on what your definition of a saw is.
You make Buckin look like a slacker.I have been concentration on acquiring monsters for the last while...
I show up to cut trees down or buck up fire wood with six running saws in my saw trailer and folks around here think I am crazy. I like to be prepared for any issues that might come up.200 is probably conservative,it depends on what your definition of a saw is.
When I bought my very first saw, it was a stihl ms441 with 25" bar. It was my do everything saw from trimming trees to cutting the down and bucking them up. I used to get a a lot of crap trimming my trees with that beast. After holding that beast up over your head to trim a limb makes you realize, that's dumb to do that. So from there on I started the saw addiction.I show up to cut trees down or buck up fire wood with six running saws in my saw trailer and folks around here think I am crazy. I like to be prepared for any issues that might come up.
No that's for retirement.Are they all working ?
