Saw popped and quit ???
HDRock Posted By HDRock, Jun 13, 2013 at 9:08 PM
Thread Status:
  1. HDRock
    HDRock
    Minister of Fire 2.
    NULL
    Oct 25, 2012
    2,239
    859
    Loc:
    Grand Blanc, Mi
    Like I said the Husky 61 popped and quit ,not a loud pop
    I was cutting, checked gas ,pretty much empty, filled it up , took a few pulls to start, started cutting , it did it again, started it up 3 more times ,ran 3-4 minutes let it idle and it just quit each time but no more popping.
    I haven't looked at air filter or any thing yet .
    What do ya think the problem is ;?
  2. NH_Wood
    NH_Wood
    Minister of Fire 2.
    NULL
    Dec 24, 2009
    2,602
    292
    Loc:
    southern NH
    Not sure - especially about the 'pop' - any chance it's overheating? Cooling fins real dirty or running lean? Might be a fuel issue since it will start but die quickly - I'd at least check fuel related fixes. Ignition issue - coil or plug going bad? Just some guesses - smarter people will have other suggestions! Good luck! Cheers!
  3. Ashful
    Ashful
    Minister of Fire 2.
    NULL
    Mar 7, 2012
    9,599
    3,993
    Loc:
    Philadelphia
    Tank breather? Try opening the tank immediately after it quits, and listen as you unscrew the cap. Does it pull air? Was the tank under vacuum?
  4. HDRock
    HDRock
    Minister of Fire 2.
    NULL
    Oct 25, 2012
    2,239
    859
    Loc:
    Grand Blanc, Mi
    When the tank was empty I could here air as I opened it, opened it again after it ran a little with full tank ,no air.
    Adjusted carb a few days ago, since then it idles fast until it warms up
    Plug is 2 months old
  5. Ashful
    Ashful
    Minister of Fire 2.
    NULL
    Mar 7, 2012
    9,599
    3,993
    Loc:
    Philadelphia
    Well, I'm no chainsaw mechanic, but I do troubleshoot complex systems for a living. When there's a new type of failure, look at recent history.
  6. HDRock
    HDRock
    Minister of Fire 2.
    NULL
    Oct 25, 2012
    2,239
    859
    Loc:
    Grand Blanc, Mi
    Thanks
    maybe I got it, lean not sure , have to check n look at it
    I didn't take much time screwing with it ,just got out the other saw n went back to work
  7. Jags
    Jags
    Moderate Moderator 2.
    NULL
    Staff Member
    Aug 2, 2006
    17,499
    6,074
    Loc:
    Northern IL
    Kinda sounds like it is leaning out.
  8. mikefrommaine
    mikefrommaine
    Guest 2.
    NULL
    Did you pull the muffler and have a look?
Thread Status:
