I called our local Vermont Castings dealer to ask about the hearth extension requirements on the VC Encore 2n1. Specifically, whether the hearth extension had to meet the same R = 1.18 value as the flooring directly beneath the stove, as I'll be setting whatever stove I purchase into a fireplace, and will need to build a hearth extension in front of the fireplace. The answer I received was, "You can't really go by the numbers in the manual, because that's based on EPA testing with very dry wood, usually oak, and the stove will put out a lot more heat than the EPA test."
Knowing they had somehow misinterpreted my question about hearth extension insulation with the heat output of the stove, I tried rephasing it, and this time was told, "You just have to put the stove on top of a non-combustable material at least 1/4" thick."
Huh?
I tried searching for a telephone number so that I could call VC direct, and talk with someone who actually knows their stoves, particularly since my install poses some challenges not remotely covered in the manual. I could not find any contact info for the company on their web site. I guess they don't want to talk to their customers?
Huh?
