All my connections that don't need disconnection were cemented together.
The ones that do need disconnection, however?
I used to seal up with a fireplace silicate cement that came in a tube, treated it as caulking.
But since I am cleaning nearly every two/three weeks...
Last night I said "f*
it".
If I do hit it again I guess just at the top and at the telescoping are where there seems to be some big gaps. But fires ran pretty good last night. Stove never jumped over 650 (was worried could have affected draft from what I was used to), didn't get smoke leakage out the pipe (just the stove door, bad draft).
So, seemed to make the room cool down slightly quicker and little longer to heat up, but hard to tell with leaky house and changing lows. But March is warmer than Feb, so thinking if I don't have any real problems come up, just losing a little heat isn't so bad.
Any thoughts on this.
it".If I do hit it again I guess just at the top and at the telescoping are where there seems to be some big gaps. But fires ran pretty good last night. Stove never jumped over 650 (was worried could have affected draft from what I was used to), didn't get smoke leakage out the pipe (just the stove door, bad draft).
