I just had a wood stove installed, connecting to my Class A Selkirk Chimney. The stove is top vent, then an elbow into a Selkirk wall thimble. The chimney installer left a DSAC connector for me to connect my stove. It would appear the DSAC connector would only be to connect single wall stove pipe. I called him up, and told him I wanted to use Double Wall, and he said double wall stove pipe will just slide over the DSAC connector, since double wall is just two different diameters of stove pipe.
Well, when the certified installers showed up, they said that wasn't going to fly for them to install the stove legally. Long story short, they special ordered a double wall stove pipe which sort of tapers on the end and I am assuming (but I don't know) at the end, the two layers of the pipe are crimped by the manufacturer to be a smaller diameter at the connector. I am sort of bummed about this setup because the pipe isn't so attractive, it has lots of joints and ribbing. Plus, they cemented the elbow to my chimney thimble, so it's going to be hard to disassemble and clean (but maybe that's protocol, I am new to this).
I'd like to redo the chimney connector if possible with the traditional DSP, that's just two different diameters of stove pipe nested inside one another. But I wanted to know if that's against code to slide the DSP elbow over the DSAC connector.
