    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. mj5001 New Member
    United States
    #1
    Helpful Sponsor Ads!
  2. EatenByLimestone Minister of Fire
    Make sure those ashes are truly cold. When banked, they can stay warm for a few days. Keep the vac outside so if something does happen, the house does not burn too.
    Matt
  3. Dakotas Dad Minister of Fire
    Central Kentucky
  4. begreen Super Moderator
    South Puget Sound, WA
    Agreed, only use the vac for cleanup, not for emptying the firebox. There is always a risk of sucking up a live ember in there. Shovel out the bulk of the ashes into a metal container. And put that container on a non-combustible surface when done.
    For cleanup, I use a dry-wall dust filterbag designed for the small shopvac. They come in 2 packs and are inexpensive. It works great and is easy to find at the local hardware store.
    http://www.shopvac.com/shopvac-accessories/Departments/Drywall-Dust.aspx
  5. EJL923 Feeling the Heat
    Western Mass
    safety aside, just use the medium or hepa shop vac filter along with a fine particle bag insert for the container. No matter the filter, dust eventually gets out. The bag insert is key. I use it for sanding drywall as well.
  6. mfglickman Minister of Fire
    NW CT
    I'll admit to using the shopvac to clean both pellet and wood stove ashes, IF the stoves have been off for a couple of days. Well, pellet stove off for a couple of hours....but it gets stuck outside in the middle of the patio for a couple of days after that. Usually I shovel the wood ashes into a metal pail, but if I need it really emptied out (like last week to replace some gaskets, I wanted it EMPTY), I left it down for 2 days then vacuumed it.
  7. corey21 Minister of Fire
    Soutwest VA
    To me it don't sound like a good idea to vacuum ashes never know when a glowing ember could get vacuumed up.
  8. mj5001 New Member
    United States
    How do you use the filter "bags" ? I have a 6 gallon shop-vac that uses a cartridge filter but how in the heck do you install a bag? better a drywall dust bag or a hepa cartridge filter I wonder?
  9. mj5001 New Member
    United States
    Ok -- saw a tutorial on the Shop vac site.
    Seems to me, the bags may be better for fine dust or ashes?
  10. Seasoned Oak Minister of Fire
    Eastern Central PA
    I bought a shop-vac from wall mart just to be able to get those big filter bags. I use it to clean chimney soot. I shovel out ashes but use the shop vac to clear ash out of the secondary air holes.
  11. begreen Super Moderator
    The bag attaches to the suction port, inside the drum. Seasoned Oak, check with your local hardware store.
  12. David Tackett Member
    Waynesburg, Kentucky
    Only time I use a shop vac to vacuum ashes out of the firebox, is when I shut down for the season and I KNOW there are no embers remaining, because the stove has not been used for a week or two. I do shop vac around my stove to clean the area, but I ensure there are no embers or coals around.
  13. mj5001 New Member
    United States
    do you use the bag WITH the cartridge filter? seems like the bg gets squeezed with it in there. I have a 6 gallon shop-vac
  14. lopiliberty Minister of Fire
    Mineral County, WV
    I was using a handheld vaccum the other week to vacuum up the hearth, and I hadn't put any wood on the fire for hours, but somehow I sucked up an ember and it started to melt the dustcup. Still don't know where it came from. I'm not going to vacuum up the hearth mess in any of my two rainbows, so I'm on the lookout for one thats pretty beat up to use around the stove so that way any hot embers will go into the water and not have to worry about fires. Just please be carefull there are no hot embers when vacuuming, let them lay there for a couple of hours
  15. clemsonfor Minister of Fire
    Greenwood county, SC
    vacuume after 2 days!!! I still have coals after 1 day and have hot embers for an easy 2 its still warm in there after 2 days!!! I do use a small vac to get ashes that have pulled out on the hearth after a reload, but only after hours of being out of the stove. ANd I do use my shop vac for the stove but only after the stove has been out for weeks!! Like at the end of the season. Once this thing is going 24/7 and has a coal bedthat is inches deep and full of ashes I will have coals in the stove for at least 3 days after a reload probably!
  16. David Tackett Member
    My FIL, God rest his soul, was vacuuming with a Kirby around his woodstove and burnt the bag off the vacuum. Cost him over 100 bucks to buy a new bag for it before my MIL beat him.
    lopiliberty likes this.
  17. turbocruiser Feeling the Heat
    Rocky Mountains Majesty
    Just to add to all the wise words about NOT using a ShopVac for ashes; I once was cleaning out my stove with my ash vac and it almost was four full days since the stove had been burning wood when I noticed a big bright red coal right under the ash that I was vacuuming up! I never would have believed it but it was right there again almost four full days after the fire finished!!! If I was using a Shop Vac that sucker would seriously have started a fire. Not worth it at all; I say either use the tried and trusted method of slowly shoveling the ash into a completely non-combustible container, or, use an ash vac but never any other regular vacuum. Hope that helps.
