Simpson Duravent Pro or ICC Excel Pelletvent? (PICS)
richkorn
640
SE CT
I pulled my stove out and removed my original T (single wall 4") between my Flex liner and the stove collar (Lopi Leyden vented into prefab fireplace and up 25'). I am upgrading and adding an appliance adapter on the stove collar, 12" straight pipe, T, and Female Flex adapter. The only thing I need to decide now is what brand to use. I'm leaning towards ICC Excel if I can find it in my area (SE Conn.), but I know many like the Duravent Pro.
Opinions?
Here is original thread regarding my venting install:
https://www.hearth.com/econtent/index.php/forums/viewthread/60415/
Thanks for the input.
-rk
Rich, I have an Enviro M55, corner installation, through the wall install with DuraventPro. The install was botched, done without an adapter. I spent last winter taping and sealing the pipe to keep the smoke from leaking out. I wasn't impressed with the design of the DuraventPro. To be fair, though, it wasn't done right.
However, the twist lock system of the Duravent is very hard to twist and lock, especially if you have to pull apart to do maintenance and repair. I was on the floor many times fighting with the thing.
In a few weeks i will redo the install with ICC Excel. No twist lock, just screws. Hope it is better.
Good luck.
Good luck.
Vinny,
Do you know how much more expensive the ICC is over the DVP stuff? i.e., if a DVP 'T' is around $100, approximately how much would the same ICC T cost?
Just trying to get an idea.
Thanks.
I have no direct experience with the duravent, but for me the excell vent has been flawless. It never leaks and remains easy to take apart. Mike -
I never quoted a T as I don't plan on using one, but I did quote an ICC Excel adapter, elbow, pipe and termination cap a few months back, and I got the impression it was like 40% more expensive than DuraVentPro.
But for ICC you have to shop different dealers because they don't sell retail online, so you pay a bit more on that front.
Hey Mike, glad you're still around here. I have emails into two dealers within 30 mi. of me that ICC web site shows as dealers. I was hoping to redo for < $400. Looks like i need flex adapter, T, 45 bend, 12" straight, and stove adapter to do it right.
Added: here's pic with T gone. The stove will be about 5" closer to the fireplace than it is now. Should be easy to put new pipe in. The Flex liner has a good 6" of play side-side and front-back. I'm hoping I can find ICC, but even DVP will be 100% better than what i had.
Rich,
I did both of my installs with Excel. The first install I did 3 years ago that way because I felt I didn't know what I was doing and therefore needed the edge. The next install I did 2 years ago with Duravent Pelletvent (not the Pro) and it was a disaster. I had leaks all over the place and could never get it right. I took a bath on it, compared the DuraventPro to my Excel and concluded it just wasn't worth it particularly since the total parts cost differential was only around $100. The Excel has a thick replaceable seal, no twist lock, laser welded seams, and depending on the install you may not even need the screws. I've taken mine apart several times and am still impressed with the quality.
I don't recall prices but I recall my first install not being more than $400-500, and it was many more pieces than you need. I should think you can do it for less than $400.
One tip I will offer: if you buy the Excel ask for extra screws. They are small than what you can find in a hardware store. The dealer should oblige no problem.
Thanks dac122 - ICC ExcelPellet vent is on order.
I have the duravent, and it does leak (I caulk the seams) and it can be a pain in the butt to take apart. I've had a lot of trouble in the past with the clean out at the bottom getting stuck. I ended up using a car oil filter removel tool to get it off.
