Small engine question - Echo 21 cc trimmer not running
hemlock
455
east coast canada
Hello,
I'm hoping someone can help me with a small engine problem. My weed eater, which was running great one day, suddenly refuses to start now. It has the same mix, same everything, except will not "turn over". After a few pulls, gas sprays out the exhaust. It is getting a spark, and getting fuel, it just won't catch. Anyone have any ideas? Thanks.
I would start by changing the plug... It isn't at all unusual on small engines for the plug to fail so that it looks good when testing outside the engine, but not work installed... Also look at the connections between the various parts in the air intake - particlularly the carb / engine joint - sometimes these can come loose and screw up your air mix.
How is the compression?
Have you checked the air filter?
Gooserider
If you've got fuel coming out the exhaust, most likely you've flooded it. The flooding might be a secondary issue if the plug has gone bad.
On my chain saw, if I pull the rope more than about 3 times with it fully choked, It'll flood. I've learned that the hard way. If it hasn't started on a few pulls, I have to adjust the choke. If it's not the plug, maybe it's just fussy.
-SF
New fuel or old? is it beyond its 5 year warranty?
