Hello all! great site! Just installed our gorgeous Hearthstone Heritage stove. Have burned wood for years but never in a stove this nice...Problem, tho..
We have 9' ceilings, black single wall pipe directly out the top of the stove. Two sections up we had to use one elbow adjusted in such a way to create a SLIGHT offset as we had to avoid the ceiling joists above where we had to go thru the ceiling. Other than that its a straight shot thru the bit of attic above and then 6' above the roof. We are beyond the 10' rule of the peak.
Here's the problem
our first regular burn of ownership, the day was very very damp, and very windy. Chimney is located on the roof nearly at the edge of house, but there is an ell and a carport nearby.My husband said that during one particular gust of wind he noticed a puff of smoke exiting at the joint of the black pipe where it goes into the ceiling collar..(All these parts came from a kit that provided all the parts needed to safely go thru the ceiling, thru the small amount of attic and then thru the roof.)
We have about 15' of TOTAL pipe as I saw that in the manual the Heritage needs at least 13'. He wants to change this pipe section as he thinks it might not be up onto the crimped section of the ceiling collar. You can see a bit of the crimping but very little. My concern is if we put a longer section there (it must be cut as it's not 24" of space) we won't be able to fit it in...you know, the chicken and egg syndrome of trying to get the sections to go together and then onto the stove!..should we not worry about it? it's the only time we saw smoke (but can smell a bit of smoke nearly all the time when the fire is low).
We let the fire go out so he can change the section but I want him to wait until I hear from someone else!
It also seems a bit hard to keep the fire going without it being a high burn (which we are trying to avoid in order to not damage the stove)
thanks
Deb
Here's the problem
thanks
Deb
