Anyone using a lawn tractor to plow there driveway and how well do they do? (Indiana not heavy snow)
SolarAndWood said:I had a 5' blade on the front of an old 25hp 2wd Kubota that I used for a few years. It was worthless without the aggressive ice chains on the rear, but did fine with them even in the heavy stuff. The tractor weighed about a ton. For our snow, I found that a 10hp walk behind snowblower is a lot faster especially in the storms.
Do they make a blower for your tractor? My father in law had a 42" blower on the front of an old 14 hp Jacobsen that rocked.
ohio woodburner said:Just make sure you use tire chains. They work great
smokinjay said:Anyone using a lawn tractor to plow there driveway and how well do they do? (Indiana not heavy snow)
savageactor7 said:I can plow our driveway 3 or 4 time in the time it took me to blow it once. If you know you're going to get dumped on you'll have to go out before it stops and stay ahead of it otherwise no big deal.
Shipper50 said:You didn't mention your tractor? I used to have a 18 horse Wheel Horse when I lived up north near Gary where the snow did get heavy and with tire chains and wheel weights I plowed a 300 foot gravel drive for 16 years. It did the job after learning how to move the snow around.
Shipper
I would think if you can find the blade for your tractor and have some weight on the back end, your good to go. With my blade, I had to manually move the blade back and forth for the direction I wanted the snow to go, but it was not bad after getting used to it.smokinjay said:Shipper50 said:You didn't mention your tractor? I used to have a 18 horse Wheel Horse when I lived up north near Gary where the snow did get heavy and with tire chains and wheel weights I plowed a 300 foot gravel drive for 16 years. It did the job after learning how to move the snow around.
Shipper
that sounds like good new shipper I am 30 miles north of indy my tractor is a lt 135 24 hp john deere and concrete drive 100 x20
Iam going to get the chains and wheel weights and weights on the back we dont get hudge amounts of snow here. If you made it with what you had and near gerry I should be in good shapeShipper50 said:I would think if you can find the blade for your tractor and have some weight on the back end, your good to go. With my blade, I had to manually move the blade back and forth for the direction I wanted the snow to go, but it was not bad after getting used to it.smokinjay said:Shipper50 said:You didn't mention your tractor? I used to have a 18 horse Wheel Horse when I lived up north near Gary where the snow did get heavy and with tire chains and wheel weights I plowed a 300 foot gravel drive for 16 years. It did the job after learning how to move the snow around.
Shipper
I also had tractor tires on my wheel horse instead of turf tires.
Shipper
You should be good to go, one suggestion, park your tractor where when you open your garage door if its inside, your ready to plow outwards. Something I learned in my old house. ;-)smokinjay said:update just order the 46 in plow chains and the suitcase type weights thanks to everyone who help and shipper you sold me! (I can still add wheel weight if need be) the rear weights are 86 lbs
Shipper50 said:You should be good to go, one suggestion, park your tractor where when you open your garage door if its inside, your ready to plow outwards. Something I learned in my old house. ;-)smokinjay said:update just order the 46 in plow chains and the suitcase type weights thanks to everyone who help and shipper you sold me! (I can still add wheel weight if need be) the rear weights are 86 lbs
Shipper
billb3 said:I've done it with a riding mower (what is sometimes called a tractor these days).
Needed chains and someone sitting on the back for weight helped with deeper heavier snow.
Supposedly hard on the transmissions. Probably more so with these hydros.
Bought a snow-blower and it is less work. Mine is a 1993/94 Snapper 824 which is a bit of a bear to turn around.
When I bought it, it didn't snow for two years (we had some slush the first year and yes, I tested the thrower).
I bought a cab for the the thrower three yaers ago and haven't had to snow throw in biting wind yet, so it's still in the box.
I have a John Deere CUT with a front end loader and used that for the last storm where we got a record 20 inches in December. I used it because I couldn't get the thrower started.
I have two long driveways and there's just no way I can shovel more than 4 or five inches by hand any more.
If I hadn't gotten the old Snapper (mostly) going Sunday, there'd be a shiny new one sitting there waiting for a trial run.
