    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Mroverkill Feeling the Heat
    Northern nj
    so my tallest nicest blue spruce fell. If i let this dry how bad is it to burn compares to say pine
    trying to see if i can burn it next year or the year after rather then tossing the wood
    #1
    Helpful Sponsor Ads!
    Scotty Overkill likes this.
  2. MasterMech Minister of Fire
    Hudson Valley NY
    What's wrong with pine? ;)
    Burn it. :ZZZ
  3. BrowningBAR Minister of Fire
    Doylestown, PA
    I don't get it. It's wood right? Dry it and burn it like everything else.
    Scotty Overkill and milleo like this.
  4. Mroverkill Feeling the Heat
    Northern nj
    BTW its a non cat stove
  5. eclecticcottage Minister of Fire
    WNY
    bummer, I love blue spruce. cut it split it stack it burn it. It'll probably be sappy though, we've scrounged a few and they were sticky sticky sticky.
  6. BrowningBAR Minister of Fire
    Doylestown, PA
    Doesn't matter.
    Dry. Burn. Repeat.
  7. Scotty Overkill firewood hoarder
    central PA
    I boiled off around 400 gallons of maple sap over a weekend last February with a 60' blue spruce providing the fuel.........now mind you it was green and in an outside evaporator, and it STILL blew me away with the amount of heat it put out! Split it, stack it, season it a year and you'll be loving the heat it puts out!!
    Backwoods Savage likes this.
  8. Backwoods Savage Minister of Fire
    Michigan
    A shame to lose the spruce but no problem burning it. Just cut it up and split it now then burn it next winter.
  9. basod Minister of Fire
    Mount Cheaha Alabama
    Downside you lost a spruce.
    Upside its not spring and the sap should be lower.
    I'll fifth the burn it!!!!
  10. SteveKG Feeling the Heat
    Colorado Rockies
    We have blue spruce all around us, and we have at least one a year die or blow over in high winds [the latter is always due to weakened trunk from beetle infestation]. Often, I find that the recently-dead/blown down ones are sappier than one would expect. Because the tree was fighting the beetles. Anyhow, this makes the wood even heavier than usual. Our trees reach well above 100 ft. tall and 28-30"+ diameter. So, a round cut to firewood length is way beyond my ability to roll it into my truck. I quarter the rounds with the saw, then either let the pieces sit in the woods a couple months or split them with my splitter. They season, up here, in a couple months or so once I have the wood split [10-15% humidity normal here].
    They burn fine. The wood does not burn as hot as ponderosa pine or lodgepole. Well, I have never measured it, but I can easily tell. But it is wood, and one tree will give you a lot of firewood.
  11. colin.p Burning Hunk
    Ottawa Canada
    I had one that died on me, around 30 foot tall, that I cut down and bucked. I let it sit for a year before getting around to splitting it. Well, it's a darn good thing I have a chain saw, as I think I pretty well had to rip most of the trunk pieces. What a bugger to split. It had more knots that a Danish bakery. It burned good and hot though.
