Starting up old Chain Saw
Dave A. Posted By Dave A., May 17, 2013 at 11:58 AM
  1. Dave A.
    Dave A.
    Minister of Fire 2.
    NULL
    Mar 17, 2013
    614
    74
    Loc:
    SE PA
    Haven't used my chain saw in many years McCulloch MAC 3818 18" 38cc. Just went to HD where am pretty sure I got it and didn't see them there anymore or any parts. Wanted to get the 2 cycle oil to mix up some gas and start it, but I guess I can use the generic and just mix at 40:1 as it says on the tank lid.
    I may have left it with gas in it (not drained) but it is empty now when I open it, so maybe I ran it dry. Any risk in trying to start it just adding new gas. Wouldn't think so, but just double checking. I know I had plenty of chain bar oil in there. That should still be there.
    Just wondering if there's anything needs done before starting it up after so long. It was never used much. But I would like to cut up some wood that's on my property.
  2. TreePointer
    TreePointer
    Minister of Fire 2.
    NULL
    Sep 22, 2010
    2,702
    1,102
    Loc:
    Western PA
    You should be fine at even 50:1 with modern 2-cycle oil for air cooled engines that specifically states use in chainsaws. Today's synthetic 2-cycle oils are very good. Mix a can of fuel and give it a whirl. If you encounter troubles, what you're likely to find is that the fuel line may need to be replaced or your carburetor needs to be cleaned/rebuilt/replaced.
    Thistle and smokinj like this.
  3. Sean McGillicuddy
    Sean McGillicuddy
    Feeling the Heat 2.
    NULL
    Jan 7, 2012
    445
    163
    Loc:
    Easton Mass. not enough time in NB Canada
    When you do add the new fuel , shake the saw up with the new fuel in it.
    TreePointer likes this.
  4. Backwoods Savage
    Backwoods Savage
    Minister of Fire 2.
    NULL
    Feb 14, 2007
    27,815
    7,368
    Loc:
    Michigan
    Good luck. Sometimes they will fire right up but most times it takes several pulls. I'm wishing for an electric start on all my engines any more...
    jackatc1 and n6crv like this.
  5. Dave A.
    Dave A.
    Minister of Fire 2.
    NULL
    Mar 17, 2013
    614
    74
    Loc:
    SE PA
    TP, SM, BS, thanks for the suggestions/feedback. Had hoped to have tried it by now, just got the gas and oil, maybe this afternoon or tomorrow.
  6. TreePointer
    TreePointer
    Minister of Fire 2.
    NULL
    Sep 22, 2010
    2,702
    1,102
    Loc:
    Western PA
    Oh, you big tease! ;)
  7. Dave A.
    Dave A.
    Minister of Fire 2.
    NULL
    Mar 17, 2013
    614
    74
    Loc:
    SE PA
    Guess I didn't warn you, I do move slow on things.:) And it started raining today, supposed to be rain tomorrow and the next few days too :(
  8. TreePointer
    TreePointer
    Minister of Fire 2.
    NULL
    Sep 22, 2010
    2,702
    1,102
    Loc:
    Western PA
    That happens here, too. I had a black locust tree dropped last August. It took me until March to get it bucked and split. I finally stacked it last week.
  9. Dave A.
    Dave A.
    Minister of Fire 2.
    NULL
    Mar 17, 2013
    614
    74
    Loc:
    SE PA
    Used to be much more diligent about getting things done around the house. But had a dumb accident with an angle grinder few years ago where I just wasn't thinking. Had to call 911 -- rescue squad, ER, staples to close the wound. Fortunately, nothing more serious than a scar. But since then, just seem to put off projects that involve certain power tools. Not that I'm afraid or anything, just have to force myself to not put things off or make up deadlines that I can't postpone to get moving.
  10. NH_Wood
    NH_Wood
    Minister of Fire 2.
    NULL
    Dec 24, 2009
    2,602
    292
    Loc:
    southern NH
    I'd try a little fresh mix in the tank, add a few squirts of starter fluid in the carb, and try to fire her up - see how she runs. If won't run well, and the saw has seen little use but sat for a long time, you can start with a check on the fuel line (cracked, real soft, etc.). If fuel line good, might need a partial carb kit - just diaphragms, and a good carb cleaning. Never hurts to take a look at the air filter (if real dirty, clean or replace) and spark arrestor screen on muffler for clogging - a couple of real quick and easy checks/repairs. Lastly, I'd pull the plug and check condition - for the money, a new plug is a real simple fix and can fix many issues with small engines.
    From what you've said, sounds like you'll have pretty good luck getting this saw running. Cheers!
  11. MasterMech
    MasterMech
    Guest 2.
    NULL
    This is a good way to break things that were not broken before you started. Substitute carb cleaner for starting fluid and you get the same results, just much safer.
    Thistle likes this.
  12. Dave A.
    Dave A.
    Minister of Fire 2.
    NULL
    Mar 17, 2013
    614
    74
    Loc:
    SE PA
    Haven't gotten to starting it yet (fixing a broken drum belt on dryer and complications got in the way). But actually kind of glad I didn't do it. Hadn't really considered the issue of the gas but after reading a thread on ethanol gas here that got me thinking. Last time I used the saw, ethanol probably wasn't even around.
    But the thread reminded me that the saw directions specified using premium gas, and I had forgotten and got regular (which I use for my trimmer and mower w/o a problem).
    So am leaning towards getting the 40:1 premix gas from Lowes for the saw.
  13. HittinSteel
    HittinSteel
    Minister of Fire 2.
    NULL
    Aug 11, 2008
    1,587
    409
    Loc:
    Northeastern Ohio
    Just mix the regular gas with any modern 2 stroke oil at 50:1.
    Thistle likes this.
  14. Dave A.
    Dave A.
    Minister of Fire 2.
    NULL
    Mar 17, 2013
    614
    74
    Loc:
    SE PA
    Why 50:1, does that increase the octane somehow?
  15. HittinSteel
    HittinSteel
    Minister of Fire 2.
    NULL
    Aug 11, 2008
    1,587
    409
    Loc:
    Northeastern Ohio
    No, but the octane doesn't matter. That little saw is no different than a weedeater. If I didn't run premium gas in my ported chainsaw, there would be no way I would waste money or even think about running premium gas in my weedeater or small saws.
    If you want to spend more, go ahead and run premium gas at 40:1, it will not hurt anything, it's just a waste of money.
  16. Dave A.
    Dave A.
    Minister of Fire 2.
    NULL
    Mar 17, 2013
    614
    74
    Loc:
    SE PA
    Was just trying to understand the reasoning/logic in reducing the concentration of the mix to 50:1 when using regular. I mean it isn't being suggested to reduce it to 50:1 with premium.
  17. TreePointer
    TreePointer
    Minister of Fire 2.
    NULL
    Sep 22, 2010
    2,702
    1,102
    Loc:
    Western PA
    The 2-cycle oil is for lubrication of moving engine parts. Modern 2-cycle oil with its additives has improved to the point that we don't need to add so much of it to a gallon of fuel. Since oil is much more expensive (per unit volume) than gasoline, I don't use more of it than is necessary.
  18. HittinSteel
    HittinSteel
    Minister of Fire 2.
    NULL
    Aug 11, 2008
    1,587
    409
    Loc:
    Northeastern Ohio
    The logic has nothing to do with the reduction in octane. 50:1 is fine with any octane.
    When someone stamped 40:1 on the gas cap lid in china, oil was not as good as it is today
  19. Dave A.
    Dave A.
    Minister of Fire 2.
    NULL
    Mar 17, 2013
    614
    74
    Loc:
    SE PA
    Okay, I got it.
    Appreciate the answers to that. I think I'm going to try a can of the premix 50:1 no-ethanol (can't argue with that 2 year shelf life) then if/after I get it working use 50:1 with regular (cause I'm thrifty) if I end up using the saw as much as am planning to .
    (But a little surprised the thread didn't get shut down before the replies appeared or before I replied. Seems these threads get shut down for no apparently sensible reason just before replies appear to a question or while I'm in the midst of sending a reply or edit.;))
  20. TreePointer
    TreePointer
    Minister of Fire 2.
    NULL
    Sep 22, 2010
    2,702
    1,102
    Loc:
    Western PA
    I just rehabilitated an Echo SRM-200 that's over 25 years old if I recall correctly. The manual calls for 20:1 and that's what someone has been running it with up until about 6 or 7 years ago. It's up and running with Stihl Ultra at 50:1, and I don't recall it ever running this clean. The Ultra cleaned up the P&C really nicely, too.
  21. tombo5000
    tombo5000
    New Member 2.
    NULL
    Nov 26, 2014
    1
    0
    Loc:
    Grants Pass,OR 97527
    So did you get it started? I'm thinking of buying a used one today for $50. I'm wondering if it's worth it.
  22. toddnic
    toddnic
    Feeling the Heat 2.
    NULL
    Jul 13, 2013
    480
    223
    Loc:
    North Carolina
    Put a little oil in the cylinder (remove the spark plug and add enough oil to lightly coat the cylinder). You could also pull the carburetor and spray some cleaner in it. Drain the old fuel and replace it with a fresh mixture. Also, I normally use a little extra oil in the gas/oil mix. The EPA changed regulations years ago to help with emissions. There is a reason why the oil mix years ago was 20:1.
    2PistolPacker likes this.
  23. 2PistolPacker
    2PistolPacker
    Member 2.
    NULL
    Oct 22, 2014
    189
    69
    Loc:
    Lenexa, Ks
    I also recommend pulling the plug, squirt a shot of oil in the cylinder, cycle the piston a couple of times, replace the plug. Since I run ethanol free premium my car I always fill a 5 gallon can to use in all my gas powered tools. A tank of fresh gas, squirt of starter fluid and give it a try.
