Stihl 361 carb adjustment
jotul8e2
595
Ozarks
My Stihl 361 is idling so fast that the chain does not stop at idle. I need to deal with this before somebody gets hurt - me most likely.
I understand about the high, low, and idle screws. What I do not know is what tool the screws take. They are deeply recessed and I can not see if the heads are slotted, torx, or what.
Use your chain saw tool, the one with a screw driver on one end and a spark plug/chain nut wrench on the other end. Insert the screw driver end into the LA slot and turn counter-clockwise to set the low adjustment (idle).
No possible way - it is far too wide. But acting on your premise that it is a slotted head I tried a 3/8th inch wide flat blade screwdriver that is just barely small enough. I think an 1/8th inch flat blade screwdriver would be a better fit. I probably have one somewhere and I will try it tomorrow.
So thanks for the help; it got me started in the right direction.
Most Idle (TAS) screws are phillips or slotted. And you are correct - it needs to be VERY narrow. Hi-Lo screws can be splined, pacman, D, double D, slotted. If I pull a carb - Hi-Lo screws go under the dremel cutoff wheel to become slotted. If you buy an AM carb, they all come slotted usually.
I've never seen a carb adjustment screw on a Stihl saw that wasn't just a plain Phillips/flat combo head. IE, use a 1/8 or 3/16 flat blade screwdriver. Might take you a while to "find" the slot but you should be able to feel when the blade engages and the screw provides resistance.
Now, the bigger question is, what changed to cause it to start idling fast? Saw chips packed in around the linkage? That happened to me, once, causing high idle.
Reactions: Giles and Jon1270
The Stihl saws I'm familiar with all take a small flat screwdriver. If you're near a Stihl dealer, they can set you up with one for a dollar or less (free at my local shop).
Ashful's right, though; you need to figure out why it changed, unless it's been doing this for years and you're just getting around to dealing with it. A high idle can be a sign of an air leak, which can destroy your engine pretty quickly if you keep running it.
Ashful--I agree. If linkage/throttle is not going back to idle, that might indicate an air leak causing a lean condition. Think of it like this--with most small engines, idle will increase just before going dead when running out of gas. Adjusting richer would just "mask" a serious problem, for a while!
