Stove Pipe Installation question
sydmeg1012
2
Groveville NJ
I'm installing ICC Excel Ultrablack double wall and Excel Class A chimney. My question is regarding the connection of the Ultrablack to the flue extension. I have the 10x10 square ceiling support installed and the class A installed with the flue extension attached and protruding through the ceiling support. I'll be connecting an 18" slip section to the flue extension. The slip section has a crimped end that goes up and fits over the flue extension. The issue is that the first 1" or so of that crimped section is single wall, then it transitions to double wall (ID 6 1/2" for first 1" then 6" after that). The flue extension is 6" OD, which means for the first 1" or so of the slip section there is a 1/4" gap between the pipe and the flue extension. ICC has advised me that I should screw through that 1" single wall area into the flue extension and not further down through the double wall area. My concern is that the screw will try to draw the pipe in to the flue extension due to the 1/4" gap and bend/deform the pipe end creating gaps. Do I just tighten the screw enough so that it doesn't start to draw the pipe edge in? What is the issue with screwing further down into the double wall area?
I had the same issue a few weeks ago. I called and was told the gap is normal but as long as the pipe fits tightly, it is fine. I asked if I could put some stove gasket in the gap and tech support said that would be fine, so I did. I already had some gasket close to the right size and wound it around twice, and the fit was perfect. Make sure you are using the longer screws for this join so that it will go through to the inner pipe. No, the screws should not deform the pipe but do not over tighten.
