    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. Joanie New Member
    We have a Lange wood stove which needs a reducer that measures 4 5/8" (not sure what the metric measurement is) at the stove connection and increases to 6 " connection for the stove pipe. I don't seem to find any out there. Does anyone know where I can get one. We had one made by a local metal worker, but it's not a good fit.
    Joanie
    #1
    Helpful Sponsor Ads!
  2. begreen Super Moderator
    South Puget Sound, WA
    Woodman parts has a listing for Lange. Call first to confirm it is the correct adapter. If that doesn't work, you might want to call Stove Parts Unlimited or Preston Trading Post to see if they have your part. This sounds similar to the 120 mm(?) start collar used on some Jotuls. The stoves I'm thinking of are the Jotul 602, which has an adapter collar that fits outside a mating flange on the stove and the Jotul 118.
    http://www.woodmanspartsplus.com/product.asp?Product_Id=170758
    http://www.stovepartsunlimited.com/detail.asp?BRAND=Jotul&HEADING=1
    http://www.prestontradingpost.com/
  3. elkimmeg Banned
    could it fit over the collar ? then what it the outside mesurements of the stove collar?
  4. RedSleds New Member
    PDX
    4.625" = 117.475 mm, so 120 mm is probably the ticket. That leaves 2.525 mm slop, which is less than an 1/8" difference (.0995" if you want to be exact) or a .050 wide gap all the way around.
Thread Status:
