    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. QandA New Member
    Question:
    Last year I purchased a new extra large Dutch West free standing catalyst wood burning stove. I have the approved stainless steel liner which produces sufficient draft,this I have confirmed with a simple wooden match check. The stove works well without the use of the catalyst but smokes on the door side when the catalyst is engaged. The seal has been checked, the wood is well seasoned ,dry and split fine. Do you know what the problem may be and how to address it.
    Answer:
    ave you blown the dust out of the catalytic converter? It's possible that this can close off some of the draft up the chimney. For whatever reason, there is not enough draft being produced once the catalyst is engaged. The wooden match does not prove the strength of the draft, only that a draft is there.
    Also, make certain that the catalyst is not plugged up with fly ash....although it does not sound as if you used the stove for long enough for this to happen.
    The chimney should be 18 feet or more tall from the stove outlet.
    #1
    Helpful Sponsor Ads!
Thread Status:
