Suggestions & Ideas Needed
26.2OrNothing
6
IMLAY CITY MICHIGAN
Hello to all:
I am in need of help and suggestions.
I have a fire place that is just for looks at best. Because of this it has been just sitting there for the last 3 years just doing nothing. I have 2 ideas that i would like to share.
One would be to remove the glass doors and place a wood stove in front of the opening and re-lining the chimney. This way would be the easy way and I would have a functioning heat source in my home. But I am unsure if I have the clearance to have a rear exhaust stove and the pipe to fit a 6 to 8 inch fireplace exhaust opening as it has a built in damper.
The other option would be to wall over the fireplace and lay brick to cover the opening and extend the hearth to fit a wood stove by adding another 24 inches. The concern that I have is, that I may not find the brick that would match. Also with this last idea I would use a top exhaust wood stove with a 90 degree elbow going through the wall and then taping to the chimney with another 90 degree elbow.
I am leaning towards the last option but the venting and drafting is a concern as the actual cost of covering the wall and build an extension to the hearth.
Let me give you dimension's for my fireplace.
My chimney is 25 feet tall.
Brand FMI
38 inches wide at the flashing
37 inches tall at the flashing
21 inches deep with door attached
Fire Box Dimensions
30 inches wide inner box
17 inches wide at rear of fire box
15 inches front to rear
17 inches tall
it sits 4 1/2 inches higher than the hearth
Hearth depth to fireplace 19 3/4 inches.
This is what I currently have and would like suggestions on what I could do and what could be done.
I have added pictures to the post
Your Help Is appreciated.
Kind Regards
Merry Christmas & Happy New year
Mike
I would start by looking at Enviro Kodiak inserts and plan for a full flue liner.
How many square feet is you house. An insert with fans, fujll liner would probably be your best option, and will heat the house. I have a two bedroom ranch, under 900 sq feet upstairs and my 1402 makes me want to open the screen door when it is in the single digits. Burn less than 1.5-2 full cords a year with natural gas bills for hot water and cooking less than20/month.
First I want to thank all that have replied.
Here is the answer to a question.
The size of my home is 1600 sf.
Now looking that the Enviro Kodiak inserts that you recommend, the question that I have is, Do I remove my fireplace or do I install this unit over the existing fireplace?
My apologies to all for my stupid questions? I am still learning.
Mike
You expressed you wanted to put a stove in front of the fireplace, so you just leave the fireplace, build the hearth out to required length is needed and run the stack out through the fireplace connected to a new liner if it works out that way. Other choice is install an insert into the existing fireplace and same deal with running new s.s. liner to the insert.
26.2ornothing that would be a beautiful fireplace for an insert to go in! I wouldn't close it up it would be a wast and more expensive to do than placing an insert in.
Good luck
Pete
Greenteam,
Yes the fire place is a prefabricated unit. Reading some of the posts here, I must reline the flue as per the temperature generated will literally melt the chimney.
To what I gather, I have to find an insert that will fit over the current unit and reline the flue. Is this a correct assumption?
Mike
No, the insert goes inside the pre-fab. You will have to choose an insert that is ZC approved. And yes you will need to reline from insert to the top of the old flue.
greenteam said:
I agree with Hogwildz, many of these prefab fireplaces were builders specials, placed in bump outs and wooden chimney chased.
what you may not see if you opened up the bump out for inspection is rusted out parts possibly charred sub flooring even charred framing material.
the floor under part of that zc prefab may not offer the radiant heat protection required for a stove or insert.
for safety concerns I think you are far better off ripping your existing ZC out and replacing it with a high efficiency wood burning fireplace.
again inserts are made to go in masonry fireplaces and chimneys not ZC fireplaces
Green, there are inserts that are made for and approved for being installed in ZC fireplaces.
Good Evening,
I will have a stove dealer come over to verify what I can do with the insert. I think talking to a few dealers that the clearance that I have may not be enough to install a stove. That said, I will let you all know what the recommendation will be.
Mike
26.2 or nothing,
This is my suggestion for you.I would run a few marathons and a 50 miler with your good neighbor that also runs. By time you put in all those miles together he would give you some good advice as to what to install. Or, I could just tell you right now what I think would look awesome at your fireplace area.
Take the mrs out to a few wood stove shops and look at a variety of stoves. Choose the one you like and if you are uncertain of brand than just write a post to all my Hearth brothers and I guarantee they will drive you in the right direction.
If I were you, I would purchase a free standing stove, bump out your existing fireplace hearth and get to burning with wood. Propane is costing you a fortune... ;-)
Sincerely, your running partner, neighbor and brother
Fredo
