SuperVent chimney
Byron Posted By Byron, Dec 21, 2007 at 7:50 PM
Thread Status:
  1. Byron
    Byron
    New Member 2.
    NULL
    Oct 17, 2007
    62
    0
    Loc:
    Shenandoah Valley, VA
    Is SuperVent chimney as described below acceptable for my Hearthstone Homestead. Does anyone have experience with this product? Thanks!
    Info from the website...
    SuperVent (Model JSC) is designed for All-Fuel applications and is listed to the USA safety standard for Factory-Built Chimneys (UL-103HT) qualifying it for use with gas, liquid or solid fuel-fired appliances (including wood stoves and fireplaces). SuperVent features all-stainless steel construction and 1" of premium solid-packed insulation.
  2. Metal
    Metal
    Minister of Fire 2.
    NULL
    Nov 18, 2005
    699
    18
  3. James04
    James04
    Member 2.
    NULL
    Oct 18, 2007
    129
    1
    Loc:
    Eastern Ct
    Not only is it correct. It can be had for $68 for a 3 foot section at Lowes. That is about half the price of most other class A chimney sections.
    James
  4. mikeathens
    mikeathens
    New Member 2.
    NULL
    Jan 25, 2007
    648
    0
    Loc:
    Athens, Ohio
    I do have to say that my Selkirk-Metalbestos SS chimney, though more expensive, seems to be quite a bit more substantial. I personally feel it's a better product, and have heard this from my local dealers, too. I guess they all have to meet the same standards, though...a 3' section of 6" Selkirk chimney is $90 at the local hardware store, last time I checked.
  5. SlyFerret
    SlyFerret
    Minister of Fire 2.
    NULL
    Feb 12, 2007
    1,457
    71
    Loc:
    Delaware, Ohio
    I'm going to be using the SuperVent chimney parts, purchased from Lowes. Seems to be decent stuff.
    -SF
  6. Metal
    Metal
    Minister of Fire 2.
    NULL
    Nov 18, 2005
    699
    18
    Just make sure they stock all the parts you need before buying, they have a somewhat limited list of parts they stock (will fit the majority of installs though).
    I am amazed that the local dealers told Mike that their pipe was the best ; ) Unfortunately UL doesn't see the difference (same clearances, same listing, etc.). I would think the service would be better though (that is what you are "really" paying for).
  7. mikeathens
    mikeathens
    New Member 2.
    NULL
    Jan 25, 2007
    648
    0
    Loc:
    Athens, Ohio
    If you compare them side by side, I think you will notice that the quality of the Selkirk product is a bit better (sturdier, heavier, etc.). But...you're right - they have to meet the same standards. I probably won't see any difference between the two during my lifetime of burning.
  8. Metal
    Metal
    Minister of Fire 2.
    NULL
    Nov 18, 2005
    699
    18
    I take it you know that Supervent is manufactured by Selkirk Metalbestos?
  9. Tracey Osborn
    Tracey Osborn
    Member 2.
    NULL
    Dec 15, 2007
    9
    0
    Loc:
    West-Central Indiana
    I bought all my Supervent from Lowe's. The only piece they don't stock is the chimney guy brace I needed due to heigth above the roof.
    If you check out Selkirk's website, they seem to offer various grades of chimney. Like Chev,. Pontiac, Cadillac from GM. The Supervent does have a limited lifetime gaurentee, so that is worth something.
  10. Byron
    Byron
    New Member 2.
    NULL
    Oct 17, 2007
    62
    0
    Loc:
    Thanks for the feedback. I just got back from Lowe's; including Virginia sales tax, I paid $579.86 for 11 feet (3 sections of 36"; 1 section of 12") of 6" SuperVent JSC chimney pipe, a ceiling support kit, 5 locking bands, and a double-wall smoke pipe vertical installation kit.
    I'm pretty well committed to building a chase and suppose I will need a wall band or two to stabilize my chimney pipe within the chase. Unfortunately, Lowe's does not stock wall bands; would wall bands for the Metalbestos pipe (which I can get from the local stove shop) work with the SuperVent pipe, or would I be better off ordering the SuperVent bands? Is it even necessary to use bands within the chase, as long as I ensure more than 2 inches of clearance all the way around the chimney pipe?
    If I decide not to build a chase, is it possible to support approximately 10 feet of chimney with a pair of SuperVent "Adjustable Universal Guy Kits"? Is it possible to substitute the Metalbestos "Roof Brace Kit" for DuraVent guy kits (because of local availability)?
    Again, thanks!
  11. mikeathens
    mikeathens
    New Member 2.
    NULL
    Jan 25, 2007
    648
    0
    Loc:
    Athens, Ohio
    I thought that was the one...yeah, I had that in the back of my mind. If you ever have the chance, compare a piece of each side by side - you'll see what I'm talking about. Don't ask why, the SS just feels better
  12. eernest4
    eernest4
    New Member 2.
    NULL
    Oct 22, 2007
    603
    0
    Loc:
    ct
    I'm no expert, but it would seem to me that if you measure the outside diameter of the chiminey pipe that you have bought, once you know that measurement, any outside chimney pipe brace that tightens down to your measurement will work.
    Not any different than buting stainless steel worm gear clamps or muffler pipe clamps.
    Just make sure that the clamp or support bracket is big enough to go around the outside of your double walled stainless pipe & not so big that it can not be tightened down snug to the pipe.
    And please, buy all the same brand clamps or braces or supports so that the bases that screw to the side of the house are all the same distance away from the house.
    Take a length of the pipe you bought with you to use to size up the support brackets to the outter diameter of the pipe.
  13. James04
    James04
    Member 2.
    NULL
    Oct 18, 2007
    129
    1
    Loc:
    Eastern Ct
    For the Super Vent the outer skin is a lower grade of SS (magnetic). However the inner tube is the higher grade (non magnetic). The Super Pro is the higher grade inside and out.
    James
  14. SlyFerret
    SlyFerret
    Minister of Fire 2.
    NULL
    Feb 12, 2007
    1,457
    71
    Loc:
    Delaware, Ohio
    I never got real good grades either. I won't hold it against the SuperVent. ;O)
    -SF
  15. GetUp
    GetUp
    New Member 2.
    NULL
    Dec 19, 2007
    26
    0
    Loc:
    NJ
    Is that right? Where did you find that out? I'm in the process of researching stove pipe for a high-salt area and this would be very important to me.
    Thanks!
  16. James04
    James04
    Member 2.
    NULL
    Oct 18, 2007
    129
    1
    Loc:
    Eastern Ct
    I have both the Supervent and SuperPro. I was using a magnetic level and found out by accident. Then I tested the interior with a magnet and found they both are non magnetic on the inside. The Supervent on the outside is shiney and has a look of polished chrome the Superpro has a dull amost like a brushed finish and is non magnetic in and out. By the way they are 100 percent compatible. That is what Selkirk tech support told me.
    James
    James
  17. mikeathens
    mikeathens
    New Member 2.
    NULL
    Jan 25, 2007
    648
    0
    Loc:
    Athens, Ohio
    I am talking the "Ultra-Temp Platinum", which is NOT compatible with the super vent. I guess they're making more than I thought...hmmmm
    I guess super-vent and super-pro are compatible?
    http://www.selkirkcorp.com/products/hearth.aspx
  18. Byron
    Byron
    New Member 2.
    NULL
    Oct 17, 2007
    62
    0
    Loc:
    Just wanted to update everyone. I finished my chimney install last night -- thanks to a headlamp and my wife's willingness to climb up on the roof with me in the dark and lend an extra hand with the roof brace kit install. My Hearthstone Homestead has been running for 24+ hours now and I love it. My wife claims I'm "obsessed with the stove." Anyone else heard that line before?
  19. James04
    James04
    Member 2.
    NULL
    Oct 18, 2007
    129
    1
    Loc:
    Eastern Ct
    Well, my Mom was visiting us for a few days. She said she thinks I might be a pyromaniac!
    James
    Oh. Congratulations on the new addition to the family.
  20. crazy_dan
    crazy_dan
    New Member 2.
    NULL
    Dec 26, 2007
    857
    1
    Loc:
    Missouri
    sorry to be chiming in late but that is what i have and it has been working good for about 4 years now.
  21. 90 Degree Elbow
    90 Degree Elbow
    New Member 2.
    NULL
    Nov 27, 2007
    13
    0
    Loc:
    Eastern Ontario
    Hello every one:
    The Hearth store I work in has been around since 1989 and the owner is a "Wood Burner" .
    We sell Selkirk ,Security, Duravent ,and ICC chimney, I have learn't from him the differences.
    A few years back there used to be a Chimney maker named GSW it was bought out By Selkirk Canada,
    The Difference Between Super Vent and SuperPro in Canada is that Supervent is sold at Hardware stores and the Superpro is sold at hearth stores. The super pro is the old GSW chimney and that is why it has a dull finish.
    The supervent is Selkirks chimney with a shiney finish.
    They both have the same warranty and the Superpro does in fact weigh more. Most Hearth people believe that the Super Pro is a better Chimney!
    I guess back before Selkirk bought GSW they had some "Rust Problems" with their Chimney?
    We sell a 6" X36" lenght of Super Pro for $89.00 Canadain.
    Just My 2 cents worth!
Thread Status:
