richg said:I replaced my electric tank with a Bosch tankless. It has dropped our electric bill by $50.00 per month.
Is that because the tankless is Natural Gas and your old tank DHW heater was electric? If so, did your NG bill increase at all?
Coaster said:Tankless Heaters are Merciless to the Electrical
Grid
Oct. 18, 2005
Paul Noel, Oil Advisor for PES Network Inc, comments that
while tankless heaters do indeed provide the customer with
substantial out-of-pocket savings on their fuel bill, they are
awful when it comes to putting load on the electrical grid
during peak times. He points out that in Florida, where
tankless heaters have become widely used, the peak power
draw is fourteen times the base draw.
What ends up happening is that the grid has to gear up to
handle peak load, and much of the energy not used during
non-peak times end up being vented (read "wasted"). Paul
says that there is currently enough energy vented by the grid
in the U.S. to power all of the vehicles in the country.
This, in the case of Florida, it could be argued that the
widespread adoption of tankless heaters has resulted in more
power waste, and not net savings on pollution to the
environment.
So if we want to reduce our energy pollution footprint on the
planet, we need to keep the broad picture in mind, and seek
for solutions that will reduce peak load on the electrical grid,
not increase it. Tankless heaters increase it, unless used
during non-peak hours.
Source: http://www.krystal-planet.com/Lates...etwork ~ KP Alluring Mainstream for RE v2.pdf
Grid
Oct. 18, 2005
environment.
got wood? said:My cousin is a plumber (30 years) in Oregon and he said one of the more efficient ways to reduce your hot water demand started with the pipes and not the heat source. His opinion is that if you have a circulating loop of hot water throughout the house (assuming reasonably well insulated pipes), you get hot water instantly and don't run several gallons first for trivial things like washing your hands, etc. He claimed that water leaving the hot water source at 120 or so degrees returns a few degrees cooler from its loop-trip to be re-heated up by just a bit of fresh hot water. He likened it to spinning a basketball on your finger and using your other hand to hit the ball in order to keep it spinning. He said a circulator pump runs at 20-40 watts...Interesting idea for new construction, but converting an otherwise star-pipe topology to a loop might be a bit much for us non-plumber-types.
BeGreen said:Flawed assumption. The system should only circulate hot water when the loop drops below a set temp point. And a good one will have a timer on it so that it doesn't run when not needed. I installed a tiny Grundfos Comfort Pump and love it. The hot water lines are all insulated and I would guess that it runs for about a minute every 30 minutes on average. The loop temp is set low, comes on at about 105 degrees and off at about 110.
I thought they might go up, but our electric bills went down as soon as we stopped running water in the upstairs bathroom just to get it hot. Difference - before about 90 sec. to get hot water. Now, about 5 sec. With 4 people taking showers that can add up quickly. We pay for our water and it's expensive, so it was a double savings.
http://www.plumbingsupply.com/grundfoscomfort.html
homefire said:These circ systems for the home should be on a timer that you set to run when you
normaly use water, say for the morning shower or after 5
when everyone is hom. Then set to turn off at bed time and while your at work..
Not perfect but it will save a bucket load of electricty to heat that little bit of water to wash your hands.
NY Soapstone said:homefire said:These circ systems for the home should be on a timer that you set to run when you
Folks, believe it or not, these do not save you heat.
Without such a device, you flush out the cold water in the pipe, and when hot water gets there, you wash. When you're done, only the hot water left in the pipe cools down, and it cools down once. That heat is lost.
With such a device, for a period of time you are keeping that pipe hot even when not using water, losing heat before you even decide to use hot water. And when you're done washing, the pipe will still have hot water. But instead of letting it cool down, you continue to put heat into it to keep it up to temperature until the timer turns off. And you lose more heat by holding it hot that long.
Heck, even the manufacturer makes that point clear on their website... it does cost energy. Maybe not a lot, but it's most certainly not saving energy.
-Colin
BeGreen said:Colin. These units have a thermostat. -*- They don't run all the time. -*- Ours runs about 24 minutes per day total.
It's also an error to assume that the hot water heater is going to kick on just because the pump as running. It doesn't always and won't unless the tank temp drops below the set point. What I think the pump manufacturer is trying to cover is for installations where the pipes are not insulated. But I can say from direct experience, insulating them makes a big difference in the frequency of cycling of the pump and the length of time it runs.
velvetfoot said:The heat is not really wasted during the heating season since it warms the house, no?
got wood? said:I think what you're saying NY Soapstone is that it uses energy, but how much is the question.
This example ignores the fact that additional hot water would been needed to keep that loop hot...how much is something I do not know off the top of my head. Would it require 2 gallons of hot water added over 2 hours to maintain a desired temp? I don't know.
brian_in_idaho said:I think homefire is hitting on one of the key points. With a non-circulating system, it's true that you loose more heat out of the pipe, delta T is higher all the time, driving more heat loss. However, the difference is that with this system you are still returning 100 or so degree water to the tank. With a "standard" system, when you flush out the cool water in the line to your fixture, you are replacing that water in the tank with 50 degree or so "cold" water, in effect loosing the additional 50 degrees of temperature difference, and however many watts/btus that were in the line. If I get the chance to play with some scenarios and typical heat loss calculations I will.
Bri
BeGreen said:Yes there will be a minor heat loss, just as there is from the hot water heater itself. But there will be much more heat lost with incoming 45 degree water replacing depleted hot water in the tank. If this incoming water is run just to get the tap or shower hot, it is much more wasteful and takes much more energy to recover from. Have 4 people doing this with every shower and face washing in the sink every day and it really adds up. If you are paying for your water it adds up more than doubley quick.
Also, the loop in our system does not feed back into the cold water. We have a 3/4 HW feed going upstairs. Just before the 2nd floor shower I have a tee where a 1/2" recirc line returns to the pump which circulates back to the bottom of the HW tank. It doesn't touch the cold water line.
