temporarily block airwash holes
jkupcha
87
Anybody have any ideas of something that could be used to block small airwash holes from working?
Background- Reviews of my stove (NZ6000) are filled with complaints about dirty glass and how the airwash is ineffective. Also as hot as I get my stove (500) I can never burn off the grapefruit size soot pattern in the upper corners. This area is exactly where the majority of the airwash holes spew the air. I'm thinking that since the air for these holes comes from external cold intakes mounted on the outside of my chase, they actually cool the glass in those areas promoting soot and keeping the temp too low to burn it off. Everywhere else the airwash does not blow stays clean at high temps.
Soooo, I would like to try and clog or block the holes to see if my theory works. So Im looking for something that might block the air but could later be removed (either drilled out or just a metal/verm barrier that could be moved)
how big are the holes?
While I kinda doubt that your outside air is STILL cold when it gets to the air wash,
I don't see why small stainless steel zip screws couldn't be used in testing your theory...
Stove cement? not sure how easy it is to clean out after say a week or so, but know how it cleans off after a year of burning. i think fine thread screws that barely grab the lip of the hole sounds the best. imo.
The stove cement sounds like a pretty good idea. I could possible paste them over the 200 holes and then give it a try. Then when I've tried it out just either push them clean with a small nail or drill them out if they stick. Other idea I thought about was using some firebrick morter. Same idea, clog the holes then just clean them out if it doesn't work. THanks.
Have you tried using dry wood?
Gonna need small splits to fit in them holes.
Did They quit making toothpicks?
he wasnt askin' why his glass gets dirty, and from my experience with walnut and pecan woods, they seem to have a lot of oily creosote output even when "seasoned". yes good wood will cure the problem, but stove cements or screws will fill the holes too!
Wood is Oak cut myself 2 years ago. TO save everyone time this unit NZ6000 is known to have airwash/dirty glass issues with everything working well, (tight gaskets, dry wood, good chimney draw etc) Even Napoleon tech is aware of the glass issue.
But what I notice is the soot is always centered on where the airwash holes (about 200) focus the air. THis air is drawn in from outside vents and used for combustion, stack cooling, and also airwash air. It does circulate around the firebox before being used (preheated) but I can't believe it is anywhere as hot as the inside of this unit and other parts of the glass. In other words I believe the airwash is cooling the glass to a temp lower than it would otherwise get from the heat of combustion. This is only a theory based on observation of where the soot seems to concentrate. I can get the stove hot enough to burn soot off the glass in areas farthest from the airwash, but the soot is thickest closest to the airwash.
Maybe I'm wrong but I thought what could hurt by just checking the theory out. Clogging some of the airwash holes doesn't sound too radical as this sometimes happens to people who burn dirty, so I don't think I'm suggesting anything dangerous here.
If you can get all around the secondary burn tube, I'd wrap it in aluminum foil as tightly as possible, then wrap with a fine wire. Aluminum melts at 1200 degrees, and although I'm sure much of your firebox is hotter than that, I think it's likely that the temp around the burn tube is going to be less than that. I wouldn't be putting screws in there because you could end up enlarging the holes and really making a mess of things. If I'm wrong about the melting aluminum, well, you can just clean it out with the ash.
Putting 200 screws in sounds a little screwy. Go with a thin coat of furnace cement.
My question is, with those covered where else does your primary air come in to the firebox? I guess finding out whether filling them will effect your burn is as easy as 1, 2... 200.
If it were me, I'd try the easiest method first. Got any aluminum foil?
You said the air comes from "external cold intakes mounted on the outside of my chase" - can you block the opening outside? That should more or less shut off your air, right?
I don't follow your theory. If it was an issue of the air getting in, why have an airwash? If letting the air in cools the glass, hat about the outside? Do you understand the reason for the airwash system? I think the issue is a poorly or ineffective design for this stove. Eliminating it will completely defeat the purpose.
Also, when you do your test and it doesn't work, are you going to get all of your plugs out? If you use anything other than a mechanical block you run the risk of having it get stuck somewhere you don't want it to be.
I have three stoves, all get some ash on the glass for a variety of reasons. I find it very easy to simply wipe it off when it builds up. All my stoves have air wash and all seem to work fairly well.
Why not just take a pc of steel and only use 2 or 3 screws and screw it over the face of the holes, even if it doesn't perfectly block them all, it should divert the air back or away if positioned right.
I agree. Besides naming the fuel as primary suspect, a lot could have to do with how the stove is loaded and how it is operated. IOW, pilot error.
The proof of the pudding IS in the eating, so go ahead and block it off with a few screws and fender washers.
All fair analysis. By the way, I've burned eco-logs and had the problem. If you read the stove reviews here on this site about the NZ6000 you will see that just about everyone has the problem. I would really love to talk to one owner who doesn't have this issue. I agree it is a design problem. Thats why I am experimenting with changing the design in a way that can be reversed. I think the best idea is to use some firebrick clay/plaster to clog some of the holes on one side only and see what happens. Somebody asked this question,- All the air enters from an outside vent and from the diagrams appears to then be divided up for three uses, airwash/combustion/ stack cooling. So blocking off that vent probably won't be an option. I will let you all know how the test works. Thanks for the ideas.
Just one more thought. Have you considered what it might do to your warranty? After all you are modifying the stove.
