So, we've been burning wood in the basement stove to heat the house now for about a year and a half and the novelty has not worn off. Replaced the non-EPA stove in the basement with a Napoleon 1450 at Xmas time and still love the heat / process / mood etc. Even my wife is into it and will now spend quite a bit of time in the basement using her laptop at a desk in front of the stove - very Norman Rockwell...
On a mild day ( the whole house is toasty - basement will run between 80 and 95, with the upstairs running 68-72, the bedrooms a couple of degrees cooler. On a cold day the basement stays 85-95, but the upstairs will hover around 67-68, bedrooms more like 65.
I'm starting to think about replacing the Gas fireplace we have in the livingroom with a small to medium insert. this would probably be run 7X24 as a primary heat source for the upstairs. The floorplan is somewhat open-ish, approx 1800 sqft upstairs, with 3 bedrooms down a hallway (see below).
As it stands we rarely use the gas fp - it burns propane and doesn't really heat much other than the couch It's rated at 23000 btu's I believe.
So, a couple of questions:
1) Does this make any sense at all?
2) How do I figure out how big an insert I can get in there without ripping out the old gas fp?
3) Those of you who have similar situations and have wood burners upstairs and down, do you find you use 1 or the other much more often? Will I start using the upstairs way more and forget about the stove downstairs?
4) Would having an insert upstairs in the LR tend to run me out of the LR? It's also our main home theatre / TV room with an HD projector and 100" screen, we do tend to spend s lot of time there watching movies, eating, listening to music, playing with our parrots and dog
5) Does a small insert make more sense in this situation? Say the size of the NAP 1100 or go for medium NAP 1400 if it will fit?
6) Am I crazy - will the wife yell at me for getting ash and wood chips all over our living room?
Thanks in advance
Thanks in advance
