True but it looks like some of the other kids in the park are jealous and want to play with us.
I'm ok with that as long as they follow our rules.
In our sand box wood boilers don't idle and forklifts are tractors. AHAHAHAHA
I have followed this thread because it's like reading a history of my experiences with my old gun with the worn center bricks, explosions, lost fires, clogged cyclones, leaking flues, muddy ash, hot flues, ash in flues, interfering smoke flap, etc,etc. I have given my opinion as to how some of these problems can be dealt with and what to expect and have met resistance all the way.Take what you will. There are about 1/2 dozen actual current WG owners actively posting on this thread. All working together to get the boilers operating as easily and reliably as possible.
Clearly we are all learning together and helping each other. No Wood Gun owner really gives a crap about "idle" vs "out". Only OTHER or FORMER owners REALLY care.
WG owners just care about making heat. Keeping the boiler running, keeping it gassifying, reloading at the optimal time, etc etc etc.
My honest and naive question to other gasifiers is this:
When your unit has reached it's operating temp and goes into idle, off, slumber or cylcing mode
Does your fan continue to operate or do you continue to exhaust from the stack?
The reason I ask this is because everyone (except WGrs) seem to be worried about creosote in their flues.
Which would occur if the unit was smoldering and allowing that exhaust out into the flue.
been following this thread trying to learn as much as i can.
with regards to timers and such, it sounds like you guys could make good use of a time delay relay. with minor motor control knowledge, this timer will start ticking (1 hours, 80 mins, 2 hours, 4 hours, whatever you want) exactly when the unit shuts down due to high temp or no call for heat. it will reset itself (might have to add another relay if you dont get a fancy one) after its own event and that will keep the WG cycling. no problem if there is a call for heat before the timer runs out, the timer relay will just reset again for your predetermined length of time. this way it will not try to turn on due to timer 5 minutes after the heat load is met just because that is what the programmable 24 hour timer is telling it to do. i dont know exactly how you would wire this into your low temp cutoff, but that is for you current WGers to figure out.
This is an interesting idea and probably would avoid the back puff problem entirely. Of course, the best way to avoid this is just what Gas has said...storage! Perhaps one day I'll have the room and $$ to put in storage. In the meantime I would be happy to learn from somebody much smarter than I am to investigate this option.
It is interesting for me to note that all the "items" Fred detailed with the exception of worn nozzle were items I did indeed experience in my first year due in large part to the learning curve, lack of large amount of storage and less than desirable wood. ALL of those issues are now dealt with and history for me. As for the nozzle, is it not something that would be a wear item on any boiler just like tires and brakes are on a car?
Although I think that bringing in outside air is a good Idea, let me tell you about my experiences with that.
Most of the times I had explosions they were self inflicted. Starting the purge timer shortly after shutdown was the culpret. My Gun didn't short cycle much because it was a little large for the load. The smoke was hard to take but when I saw the flame that came with some I decided to go through the wall with it. It became a magnet for hornets and wasps that were looking for a new place to build a home so I got a nice little aluminum hood (the ones they use on single 100 lb propane tanks) Looked good. I didn't have to look at a hole in the wall. I then put 1/8 inch hardware cloth on the opening.The first explosion sent it about thirty feet out into the back yard with about 10 square inches of cedar siding attached. Decided that the mesh didn't allow the gas to escape quick enough so I removed it. Next explosion did the same thing. I concluded after a few more that the gasses don't like to turn corners.
To avoid these "explosions" I have done nothing other than to avoid exactly what Fred states, which IMHO is operator error, and not purge soon after a shut down. I have not had one of these happen except in the very early days of operating the boiler. Actually, most of the initial shortcomings for me with this boiler were operator error of one form or another.
What is the advantage to bringing in outside air? I suspect none for me as my basement is certainly not a sealed environment?
I honestly don't remember. It didn't interfere with the door if I remember correctly so it couldn't have gone too far down.Did you bring your intake down to the floor first and then back up?
That sales pitch was why I didn't buy a woodgun. At first I liked the apparent simplicity and the off the shelf controls. But telling me that I could stuff it full like an OWB, let it cycle on and off and be fine.... Just as long as you 'upgrade' to stainless. Didn't pass the straight face test for me. Sounded more like what I'd expect to hear from Larry B at the county fair.The only reason I can see as to why idle, shut off, slumber definations are such an obsession is because that statement in the salesman's pitch is the reason you bought the unit..
One thing that came to mind on bringing in outside air which you should know in advance is thay the cold air entering really cools the box and flap causing the flap to collect condensation. It makes for a pretty gooy, smelly mess in the box. I remember spooning out the puddle on several occasions. The other problem as a result of the condensation was that it caused the silicone gasket on the flap to strech which caused it to ripple, eventually causing it to not close tightly and allow air into the firebox. Mine went into overheat a couple times. Blew the t/p valve and made some steam. First time it took a few minutes to locate the problem.
