Thoughts on a ceiling fan in the basement.
Wildo Posted By Wildo, Apr 11, 2013 at 9:37 PM
  1. Wildo
    Wildo
    Minister of Fire 2.
    NULL
    Dec 14, 2011
    543
    182
    Loc:
    jackmanistan, maine
    I just came to the conclusion that a ceiling fan in the basement might really help any thoughts?
    We already have one on each of the other floors.
    Or is cold air returns and simple convection the way to go in the basement?
    Would the turbulence block the flow of cold air down or would it enhance it depending on blade direction?
    Note that this is the current set up(no forced hot air or water).
  2. realstihl
    realstihl
    Minister of Fire 2.
    NULL
    Dec 4, 2007
    525
    64
    Loc:
    eastern kansas
    I have a ceiling fan in the basement. It doesn't work well with the woodstove if you're trying to get heat to the second floor. That's the way it works in my basement.
  3. savageactor7
    savageactor7
    Minister of Fire 2.
    NULL
    Jan 25, 2008
    3,708
    10
    Loc:
    CNY
    I think your on to something Wildo. If your basement can safely accommodate a ceiling fan than go for it. As a long time 24/7 firewood burner we appreciate the utility of fans...they do even if marginally, make primitive heating better as far as moving the air around.
  4. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    61,607
    7,878
    Loc:
    South Puget Sound, WA
    A ceiling fan is best for breaking up heat stratification during the winter. Usually this is not an issue in a basement which has a goo convection path to upstairs. If not, improving convection will have better results. If you do put one in, watch the ceiling height or someone may get an unwanted haircut. :eek:
    raybonz likes this.
  5. Wildo
    Wildo
    Minister of Fire 2.
    NULL
    Dec 14, 2011
    543
    182
    Loc:
    jackmanistan, maine
    I was wondering if the extra turbulence would get more heat moving up the stairwell which is in the sw corner about 10 off the left side of the stove. The basement runs in the 90 temp. range now.
    A fan that can flush mount will fit between the joists (24 on center) and its a full 8' to the bottom of the joists so no hair cuts plus I'm almost bald now anyway.:(
  6. savageactor7
    savageactor7
    Minister of Fire 2.
    NULL
    Jan 25, 2008
    3,708
    10
    Loc:
    CNY
    A set up like that would restrict the draw of the blades and overheat the motor...you don't want to do that.
  7. Wildo
    Wildo
    Minister of Fire 2.
    NULL
    Dec 14, 2011
    543
    182
    Loc:
    jackmanistan, maine
    crap didn't think of that, thanks
  8. Wildo
    Wildo
    Minister of Fire 2.
    NULL
    Dec 14, 2011
    543
    182
    Loc:
    jackmanistan, maine
    What if it is mounted like that right next to a large cold air return???
