I recently bought a used St Croix York pellet insert rated for ZC installation and will be installing it in a maufactured fireplace. The existing flue pipe is a Preway 8" ID flue. I will be using 4" pellet vent, probably Excel. In an effort to keep the existing flue pipe as cold as possible (for ice dam reasons), I have been considering insulating the vertical pellet vent pipe with ceramic (cerawool) insulation by wrapping it with insulation help in place with wire mesh, probably chicken wire. The vertical vent will be about 20 feet, plus or minus. I understand it will draft like crazy. Will it damage the pellet vent in any way? Will the gaskets get too hot? McMaster-Carr sells the cerawool blanket in 24" wide X 25' rolls for less than $30. I've heard of wrapping the flex behind the stove with cerawool but haven't see much for wrapping the flue. TIA.
