murph said:Aaron do you know what you need for an r value below the stove? Just asking cuz I almost go into trouble with that myself. I had to add 1" of micore (fibreboard) to get the insualation value required for my NC-13. Unfortunatly I checked that after I had already tiled the hearth for the first time.
oops!
Aaron Pasteris said:Murph
I had thought about dropping a layer or two of micor on the sub floor and mounting the metal studs flat but the micor wasn't easily available.
My biggest fear was cracking the large tile so I jumped several times on the hearth before laying the tile - 180 lbs bouncing on it didn't have any perceptable movement and caused no cracking so if the tile cracks I'll know it's from the heat.
Anyone know how to get a 'wet' look on the tile? There are stone sealer-enhancers but I'm afraid to use one - it's a lot of work to pull the tile if it goes bad. The tile looks great as is but the grain (???) realy comes to life if it's just moistened.
Aaron
Link to Pictures: https://www.hearth.com/econtent/index.php/forums/viewthread/45240/
