Hello everyone. I am new to the Pellet Stove venture. I know people who have them, some love them, some hate them. I had / have natural gas furnace heat, but for some reason, even though the price is at a all time "low" my budget bill doesn't reflect it. So I turned to a pellet stove vs. wood stove.
With that in mind. After installation I am now getting some sort of vibration at various times. Sounds like the fan, but it's fine. Can not be felt through the stove, but you can hear it. It does it before the actual fan blower cuts on. Could it possibly be the auger?
. Those three buttons are fine tuning type controls that let you tweak the burn. If the stove is running fine you don't need to play with them, but if it starts to burn dirty (and you are sure the stove is clean) you can use those to change the fuel/air ratio. The buttons are known as LFF (Low Fuel Feed), LBA (Low Burn Air), and Air On Temp (AOT). If you tweak any of them, you only want to change one at a time and give the stove 5 to 10 minutes to adjust before changing again, but you NEVER want to change AOT as that changes the temperature threshold under which the room air blower turns on and off and changing that setting can cause the stove to overheat, probably not something you want
