    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. velvetfoot Minister of Fire
    Sand Lake, NY
    I'd like to do my own maintenance.
    Thanks.
    #1
    Helpful Sponsor Ads!
  2. RoosterBoy New Member
    CT
    not a good idea you will have to calibrate the sensors the co sensors must be clean and the equipment is not cheap. checking for trace of smoke , draft , stack temps , co. there's allot and you have to know how to adjust the burner and understand the numbers.
    here is what id recommend you learn.
    if you have a boiler and want to clean it yourself get a vacuum that will take the soot. then get someone that you trust to adjust your burner and set it up. ex: not the guy that sell you oil ;-) but someone else.
    because usually once it's setup you never have to touch it just clean the boiler change the nozzle and stainer. and your oil filters. prime the pump. and your good to go.
    this way here you don't have to buy any equipment.
    good luck
    Jason
  3. elkimmeg Banned
    Depends on the oil burner age older ones 1970's about the only variabe one can tweak is changing the Nozzel
    Nozzels have different spray angles and vollumes. Most are tested with a draft probe in the stack pipe.
    More modern boilers are equiped with circuit boards and computerized Not really user adjustiable.
Thread Status:
