First time wood stove installer here, this website has been a great resource. Quick questions.
1. From my flue collar, should the first section of stove pipe just rest inside of the flue collar? Should it be attached or sealed in anyway? I'm using Snap-lock, which doesn't seem to make a perfect circle fit. Should I be concerned if it is not air-tight?
2. From my masonry chimney hole, how do I attach my last section of stove pipe? My last section is a 6" to 8" increaser with a trim collar. The increaser does not fit firmly into the chimney hole, with about 1/4" of wiggle room. How would you suggest attaching the increaser to the masonry? I have Rutlands furnace cement, but really no clue on the curing process. To cure to 500 degrees, can I just burn a fire?
3. My chimney is all masonry/bricks. Do I need chimney pipe inserted into the masonry?
Thanks in advance.
Thanks in advance.
