Trouble with heat setting 8 on pdv
Pellet rick
524
Pottstown PA.
does anyone else have an issue with the stove top auger stop feeding when you increase the heat setting to 8 or above? I’m wondering if I’m tripping my overheat sender since I did all the modes and the stove is kicking ass. Now for what I have done. Bottom holes plugged, burn plate holes enlarged , mode to C , exblaze pellets. Runs great on setting 7 but in this fridgit cold I wanted to turn it up
If you tripped the high limit the stove would shut down completely. How old are you augers? I cant run mine above 5 its just to warm in my office. But it will go there. Ive done all the mod’s also.
4 years but it runs fine up to 7 just can’t push it to 8. When it does it and I back it Dow to 7 the auger will start working again after a few seconds. Strange
Yes another of englands quandaries
Ssyko update on my issue. After more investigation my upper auger is working correctly. My problem seems to be my new load of ezblaze pellets that I started using. It seems that there burning up faster than the auger can feed them. Does anyone know of a way to increase the feed rate above heat 2? I already opened the hopper plate all the way.
