    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. chrisasst Minister of Fire
    cortland ny
    So I had to get several bags of Instant Heat pellets. They burn fine in my EF2, but in my Englander PDVC, I woke up this morning to a pot full of barely chard, incomplete, unburned pellets.
    I had the bottom three on 5-4-1, I leave the heat/blower on 9-9 because I have it on tstat.
    Any tips on what numbers I should try using these pellets, or what to do.
    #1
    Helpful Sponsor Ads!
  2. jrsdws Feeling the Heat
    Central Illinois
    I don't know what factory settings are for PDVC but you need more air. Increase LBA so it's 2 or 3 numbers higher than LFF and it'll be better. So maybe 5-7-1 or perhaps 3-5-1.
  3. CT Pellet Minister of Fire
    Torrington, CT
    Most likely an airflow issue. This is usually accompanied with a thisk, black sooty build-up on the inside of the stove and clearly visable on the glass. May also want to check all gaskets and also make sure that you do not have a clog in the pipe somewhere. Good luck.
    kinsmanstoves likes this.
  4. chrisasst Minister of Fire
    cortland ny
    I'll try 3-5-1 see what happens.
    For whatever sense it makes. the glass is less dirty than with burning barefoots..
  5. CT Pellet Minister of Fire
    Torrington, CT
    Now thems fighting words.....:(
    But definitely try the new setting.
  6. kinsmanstoves Minister of Fire
    clean the stoves.
    Eric
    CT Pellet likes this.
  7. WoodPorn Minister of Fire
    I burn my PDVC @ 551 on 1/3 or 2/4 for more heat
    and 441 on 1/2 when not so cold, have not had an unburned pellt issue.
    was the door cracked open by chance?
