What kind of results has anyone had installing pex under a conventional floor joist first floor. Thinking of stapling pex then light spray foam on bottom no transfer plates.
Stapling PEX to a sub-floor is hasn't been done for along time. If you are referring to a suspended tube system you might have something for floor warming in a warm climate.
For designs in all of Wisconsin we use plates or Ultra-Fin according to the heat load for the room in question. Fiberglass is the standard. Reflective surface is not worth trouble.
If you use plates foam will work fine, again, depending on the heat load.
No heat load, know nothing...
y'know. physics.Please explain further how aluminum plates improve the heat transfer? As I understand it they help spread out the heat transfer and avoid hot spots but don't actually increase it as long as the design and amount of pex used is exactly the same. From my experience they more than double the cost of the installation so most people don't bother with them in the NW, staple up is still the most common method for retro-fits here with little negative feedback.
y'know. physics.
the same way that a copper pipe delivers more heat when it has a bunch of little aluminum fins around it in baseboard radiators. Pex by itself is a poor conductor, so the aluminum contacts a large area of the pipe rather than just the little bit of sub-floor, which is also not terribly conductive.
that's the thing about doing it the best way possible. reduce the risk that something is going to go wrong, or not perform the way you hoped.Yes, those aluminum plates get very warm quickly and transfer heat directly to the floor. You insulate right up against them instead of leaving a space to heat the air pocket typically done with the staple up. But, I'm no expert by any means, in fact I don't have a lot of experience with radiant floor heating so I'm glad my system is working very well because besides all the homework I did before the installation, it was really a risky experiment.
I am not sure where to post this question: We have a hose that permeates oxygen in a hydronic heating system. We want to know which is the best chemical inhibitor to use to remove the oxygen?
