Anyone ever do this? I change oil on lawnmowers and cars. I end up with this oil. A guy from a local tree service uses old oil as bar oil. Says he has for years without problem.
Anyplace that sells oil will take it back for disposal. It's the law. Or if you accumulate enough of it, there are companies that will buy it from you.
Yah, used crankcase oil is really messy stuff. I bought a used 026 once from a guy and it had used motor oil in the oil tank. Had to drain the tank, then had to clean it out, then had to remove all the grime on the saw where that crap had gotten into. It had a bad smell to it as well. That wound up being my 026 doner saw. I swapped all the crappy parts from my 026/260 collection onto it and all the good parts from that saw to the others. Then I sold it really cheap on CL as a beater. It ran good but... it was seriously abused.
I mix bar oil and my used engine oil. Its called recycling. It goes back to mother earth fast that way.
I have done this and also have run canola oil straight and it has a light tack to it and works very well too.. A couple respected chainsaw people here have recommended this and do it as well.. Zap does lots of cutting and uses straight canola oil.. I bought Walmart brand pure canola oil cheap and it works great and flows excellent in cold weather..This thread has me thinking of mixing bar oil and canola oil 50:50. That way I get the tackifier in the bar oil, and reduce the pollution by a factor of 50%.
