Are most people using outside air for combustion in their wood stoves in air tight homes? If so, do you feel there is a benefit to it?
JimboM said:Flex was easy for me to install and it prevents condensation.
snowleopard said:JimboM said:Flex was easy for me to install and it prevents condensation.
If I may jaywalk here, how does insulated flex duct prevent condensation?
Some interesting points in this article, but it is more hypothetical than scientific.WhitePine said:We planned to install one, but after reading the following article on woodheat.org decided against it.
http://woodheat.org/index.php?option=com_content&view=article&id=81&Itemid=15
We do have an ERV.
triathlete said:Some interesting points in this article, but it is more hypothetical than scientific.
elmoleaf said:1. One reason for outside air--no matter how tightly your home is constructed--is so that inside air that you've spent money to heat does not get sent up the flue to outside. Presumably your wood/money goes farther if you don't have to keep heating a constant stream of outside air that leaks into your home to replenish what you're taking from inside.
elmoleaf said:2. Another reason for using outside air is a new home that has a well-installed continuous air barrier (think Tyvek or similar) with properly installed doors and windows etc. and has very little air leaking to the interior. That situation means when you take combustion air from inside, there's no natural air leakage to replenish it. A flue might not draw well in those circumstances, just like it's difficult to suck air from a straw with one end closed. However, a new home does not guarantee an airtight home....only a blower door test can really confirm how air-tight your home is.
Thanks for this article. I agree ... it seems more convincing to me too.John_M said:triathlete, as a counter to the excellent argument presented in woodheat.org, I would suggest you also read this excellent argument: http://www.chimneysweeponline.com/hooa.htm
To me, the argument at chimneysweep is the more intuitive and convincing of the two.
