Vent alignment help
mikkeeh
443
NE Ohio
Im sure this will sound stupid...but here goes. Im moving my P43 from a basement to an upstairs corner location. Originally, I went straight out to a cleanout "T". The corner install dictates the use of a 45, then out to a "T". Im using duravent....not the pro series. When I lock the cleanout "T", it ends up at 10 oclock or 2 oclock roughly. With the straight out setup, I could adjust the appliance adaptor, but that wont work with the 45. Im sure Im missing something simple...so any advise appreciated.
I'm thinkin you need an adjustable 45. You will probably hafta tape it tho. Them things are leaky...
I can get a partial lock on it . I suppose I can silicone and screw it together. Just thought someone else had a good solution. I cant be the only person to run into this??
