Vented Logset pilots and wind
Millbilly
300
02648
A question more for other pros. What do you consider reasonable wind speeds for vented gas logsets in masonry and manifactured fireplaces to hold a pilot. Trying to set expectations for customers. Today it is gusting 35 to 40 mph
Interesting subject. Never heard that question, so I can't answer.
I've been in hearth business on & off for the last 20 years,
including install & service, & that has never come up.
On a windy day like today, it might be a good
idea to call someone WITH a standing-pilot vented gas log set &
see how they're making out.
I'd like to hear the answer, too.
I have encountered this issue in the past. people usually have the damper all the way open. it’s like a open window blowing down the chimney .I try to set the damper clamp so that when it’s closed it’s just a little over the minimum. Like 10%. -20%. That way they don’t have to worry about opening and closing it. .Some people just remove move after it’s installed and then complain that the pilot keeps blowing out when they use because the damper is wide open.
  • Vented Logset pilots and wind
Reactions: DAKSY
From what Ive been told in Massachusetts the damper has to be removed.
